Front Door
Like Tree3Likes
  • 1 Post By robadat
  • 1 Post By _PTGT03
  • 1 Post By Busted_PT
Old 20 Oct 2016, 12:03 pm
Default Front Door
what is that mechanism called that holds the door open? its attached to the car frame and goes inside the door. mine is clicking when i open and close the door and driving me nuts. i sprayed with wd 40 but no fix.
Old 20 Oct 2016, 12:36 pm
Default Re: Front Door
That thing is called a door check. You might try using some lithium grease on it.
Busted_PT likes this.
Old 20 Oct 2016, 12:48 pm
tried that too. i am going take the thing out and see whats going on. just wanted to know in case i have to hunt for a new one. Thanks much
Old 20 Oct 2016, 06:49 pm
_PTGT03's Avatar
it is common, after time and use that the steel tab welded to the door frame holds a pin. the pin with pressure causes the hole to oval and makes a noise because it's no longer performing its job properly. this is common across automotive manufacturers who use this same design. chalk it down to just poor engineering. compare the mercedes door hinges to chrysler. big differences !
you would have to cut a good tab off from a wreckers car from the passenger side, flip it over and then weld it in place of the old one in the drivers' door.
dougs likes this.
Old 21 Oct 2016, 08:31 am
Well this answered a question i had but chalked up to "older cars make noise".
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 21 Oct 2016, 09:09 am
Fk5 Fk5 is offline
Doesn't every parts store have some cheap helper bushing to put in the oval-ed hole?
2003 GT 5 speed
162,000 miles
Old 26 Oct 2016, 12:28 am
LionPT's Avatar
Is this it..??
01-05 PT CRUISER DRIVER FRONT DOOR CHECK - OEM
EDIT: Forgot you had a 2008...
Old 26 Oct 2016, 06:40 pm
Thanks much. Weather has been horrid around here on the weekends recently, plus yard work so I have not gotten to it. Wow, that thing looks intense.
Old 26 Oct 2016, 07:03 pm
Nothing is welded on our cruiser doors. Hinges or the door stop. All bolt on.
Old 26 Oct 2016, 07:18 pm
If you are up to changing it the amigos want to help you out. As Skyling767 would do, I can send you one for the shipping. It is used. Let me know.
LionPT likes this.
Front Door Speakers MikeGlosta Sound and Security Forum 6 04 Sep 2016 12:09 pm
Front door cadillac General PT Cruiser Discussions 3 09 Jul 2012 07:32 pm
Need R front fender and door J3t Classifieds: Want To Buy 1 26 Oct 2011 12:04 am
WTB pass front door awdrst Classifieds: Want To Buy 4 04 Jan 2009 03:38 pm
Front Door Speaker Dimensions? yobiebs Sound and Security Forum 5 23 May 2003 01:07 pm
