01' Tranny Slippin
Old 22 Oct 2016, 09:37 am
Default 01' Tranny Slippin
She's an 01 with 148k mi replaced her engine last January 15 this summer replaced radiator , then recently there was delay when Shifting to drive then I had a transmission fluid service seemed to help then recently she's been givin a delay in 1st gear, ill press gas and it'll take a moment to go not
Everytime but sometimes , mechanic says might need a tranny, what $cost am I looking at? Is she worth saving or is this the end of the line? It's
Old 22 Oct 2016, 01:17 pm
Default Re: 01' Tranny Slippin
You need to find out if the mechanic used ATF+4 fluid and changed the filter too.
I just replace a automatic (2007) and picked one up for $200.00 (Self install)
Is your engine service light on?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 22 Oct 2016, 02:57 pm
I agree with Joe. If the shop you used didn't put ATF+4 in it, then they screwed it and you. Where are you located? Yours appears to be in pretty good shape.
Old 22 Oct 2016, 03:31 pm
rob302's Avatar
If there was a delay in shifting and am mechanic changed the fluid for hopes and dreams, it would be pretty mean to blame the problem on the fluid change instead of prior abuse and lack of maintenance, no?
We just had a big discussion on another forum about how people neglect their trans maintenance, change the fluid expecting miracles, and then blame that when it takes a dump.
Old 22 Oct 2016, 03:40 pm
Double checked with valvoline on if they used ATF+4 fluid they said they did , asked if they also changed the filter they said no
Service engine light is not on. Sent her to get new tires at Firestone today they put a note on there that transmission is weak and when put in drive rolls back alittle.
I live in Antioch, TN just south of Nashville
Old 22 Oct 2016, 03:51 pm
I don't know if any repair shop that would change the transmission oil but not the transmission filter. I would recommend replacing the filter and see if that helps.
Old 22 Oct 2016, 04:35 pm
Maybe since it wasn't a repair shop it was a valvoline instant oil change place I had the transmission fluid service done
A service center just told me that PT requires tranny to be rebuilt in order to change filter can't be serviced seperate, says they send rebuilds out to Seperate place
Old 22 Oct 2016, 05:19 pm
ok. never go to that service center. ever. the filter is designed to be changed by anyone who can turn a door knob.
any how, it might be worth another fluid and filter change- if the car is paid for...I'm assuming the shop just sucked all the oil out of the dip stick tube then?
one thing is fact for you. try another shop.
Old 22 Oct 2016, 06:32 pm
Yes again I had the transmission fluid service done at a valvoline instant oil change place they aren't a repair place, they just offer a $150 suck out the oil from dipstick tube while you sit in your car then they pump new fluid in it... now the repair shop I called that told me the filter can't be changed they haven't done anything with the trans I just was calling them to see.
What I'm thinking of doing is going to a local transmission repair place just to get it checked and see what they say. She's driveable right now just the slipping is a concern
Old 23 Oct 2016, 05:42 am
150$?!! unless I saw the correct fluid go in it id... uh.... please tell me that was a full bumper to bumper fluid (and brake fluid) change. for humanity...
std tranny samael General PT Cruiser Discussions 1 14 Sep 2012 03:06 pm
When my tranny goes... ucantcme Tech & Performance Forum 1 06 Oct 2008 05:17 am
02 tranny azmexicali Tech & Performance Forum 2 17 Nov 2007 11:38 pm
Tranny ? umaxman Tech & Performance Forum 29 30 Sep 2006 12:56 am
GT Tranny sakigt Turbo Performance 3 03 Jul 2003 02:25 pm
