Power steering issue, works but super loud, New pump & fluid
  • 1 Post By thecabinguy
Old 29 Oct 2016, 12:46 am
Default Power steering issue, works but super loud, New pump & fluid
Previous owner drove the car with an empty PS pump, took the belt off but he knew he burnt up the pump.
Installed new pump and belt, this one has the square reservoir. Flushed and blead the best I could. The steering feels good and works like it should, but it's loud as hell.
The only thing I noticed is that it had red PS fluid and the new stuff I put in is clear. But I made sure it was the correct type of PS fluid.
I did put the front end in the air and bleed it out side to side over and over etc... Fluid is at proper height in the res.
I've read about the reservoir having an uncleanable screen in it and if it clogs it must be replaced. Are they referring to the round reservoir? A new square type res is almost $200 new.
Any ideas??
Old 29 Oct 2016, 02:02 am
Default Re: Power steering issue, works but super loud, New pump & fluid
The 03 I had sounded like it was sucking air instead of fluid when I purchased it. What I did was remove the reservoir and clean it with brake cleaner and reinstalled it, (yes there is a fine screen in it do not damage it)
connect a length of hose to the small line from the rack using a plastic connector or a short piece of copper tubing, enough to reach a clear half gallon container,
use a piece of hose on the return fitting and keep it higher than the reservoir or a short piece of hose with a plug in it to keep the fluid from draining out.
connect the larger front hose and refill the reservoir and have some one start the engine, let it idle and keep pouring the correct power steering fluid into the reservoir until the fluid comes out clear.
Reconnect the return line and test.
I had no more problems or noise with my PS.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 29 Oct 2016, 09:52 am
Handy_Cruiser's Avatar
Make sure you ONLY have ATF +4 transmission fluid in the reservoir. On the two turbo PT's I've owned, it's MUCH quieter using ATF +4. And I've had to change it out to ATF +4 on every PT I've owned.
Old 30 Oct 2016, 09:48 am
rob302's Avatar
you should elevate the front tires off the ground so there is no resistance to damage anything, and then turn the wheel right an left repeatedly. do not hold it at the lock. should help quiet it down. seems you already did that though?
if you have a rebuilt pump they are a gamble. my way is like the bare minimum thing that should always be done before driving.
the right way is to follow the TSB here(scroll down a bit): 2001 pt cruiser: aftermarket..pump hose and rack, keeps cutting..pumps
someone on here removed/stabbed open the screen with good result.
Old 30 Oct 2016, 11:35 am
thecabinguy's Avatar
When I had my power steering serviced on my '05 just last year, the fluid that was put back in was the red ATF4 trans fluid. Seems to be doing just fine. Is this the wrong fluid?
***** I just read Handy_Cruiser's post. I feel better that I do have the correct fluid in my car. Whew!
Handy_Cruiser likes this.
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Power Steering Fluid Leak TheAstronomer Wheels, Tires, Suspension 2 12 Dec 2013 10:49 pm
Power Steering Fluid Aquamarine General PT Cruiser Discussions 1 01 May 2013 04:21 pm
Power Steering Fluid ptal Tech & Performance Forum 4 05 Mar 2010 09:40 pm
Power Steering Fluid jmack General PT Cruiser Discussions 12 25 Dec 2008 11:55 am
TSB on Power Steering fluid? PTGT Redman Tech & Performance Forum 10 31 Mar 2004 06:42 pm
