Which PT Cruisers need to have upper intake removed to change spark plugs?
Like Tree9Likes
  • 1 Post By Moparman440
  • 2 Post By CREWZIN
  • 1 Post By quicksilverdon
  • 2 Post By CREWZIN
  • 1 Post By chuzz
  • 1 Post By Busted_PT
Old 06 Nov 2016, 10:41 am
Default Which PT Cruisers need to have upper intake removed to change spark plugs?
Guys,
I have seen several references on here as to having to remove the upper intake manifold just to change the spark plugs. Is this on the naturally aspirated models?
I'm wondering because I have a turbo with aluminum intake and a turbo with the composite intake and I have changed plugs on both without pulling the intake.
wingman55 likes this.
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Old 06 Nov 2016, 10:54 am
Default Re: Which PT Cruisers need to have upper intake removed to change spark plugs?
The N/A (non turbo) models need to have the upper manifold taken off. The width of the runners on the non-turbo's makes it impossible to get to all the plugs.
Old 06 Nov 2016, 05:31 pm
Yup.
I have changed plugs on turbos with aluminum and composite manifolds without taking the intake off - with swivel sockets.
On the N/A, manifold has to come off.
Old 06 Nov 2016, 05:35 pm
rckstein's Avatar
So on the N/A, could the intake have been designed to allow for access to all the plugs? Or because it is composite, it had to be designed how it is for strength, thus blocking access to the 2 middle plugs?
Old 06 Nov 2016, 06:05 pm
Personally I would have thought they could have designed the N/A plastic upper manifold the same way as the turbo so access to the plugs would have been easier but I'm not an engineer.
rckstein and Carnut like this.
Old 06 Nov 2016, 06:08 pm
rckstein's Avatar
That's what I was thinking, because it was obviously done on the turbo
Old 06 Nov 2016, 07:00 pm
LionPT's Avatar
Most turbos that have the composite intake...the difference in the turbo & N/A intakes is for air flow.
Old 07 Nov 2016, 07:55 am
I have the aluminum intake on my turbo. I can change the plugs in it in about 20 minutes. That's about the ONLY thing that's easy to work on on these 2.4's in the PT.
rckstein likes this.
Old 10 Nov 2016, 05:52 pm
Ha ha, yeah Chuzz, but don't forget the multi function switch, that is an absolute breeze to change on the PT as well.
I forgot to mention that the aluminum intake is MUCH easier to change the plugs on than the turbo composite. I'm sorry to hear that the N/A cars are such a pain.
chuzz likes this.
Old 11 Nov 2016, 10:47 am
They didn't factor any of that in. As per mopar. You are instructed to remove the intake to Change plugs in all PTs. But allowing for access wouldn't affect strength.
How often to change the spark plugs??? rockandroller Tech & Performance Forum 11 14 Jun 2016 09:58 am
Change spark plugs on my 2004 Arca84 PT Cruiser News and Rumors 19 21 Apr 2015 09:42 pm
need some guidance to change spark plugs in my GT turbo BrianW General Turbo Discussions 1 09 Jul 2010 12:38 am
Any advice for my first oil change or replacement of spark plugs? TheFox General PT Cruiser Discussions 3 14 Sep 2008 11:24 am
Should I change my spark plugs/wires? crazie.eddie Tech & Performance Forum 8 18 Sep 2004 09:30 pm
