2001 key transponder bypass
Like Tree6Likes
Old 06 Nov 2016, 11:47 am
Default 2001 key transponder bypass
u all were great and helped me before, olz help again, lost my keys, i just want the easiest way to bypass all that crap, i dont need it.....
thanks a million
Old 06 Nov 2016, 02:57 pm
Handy_Cruiser's Avatar
Default Re: 2001 key transponder bypass
If you have lost your only gray sentry key, you are out of luck. It will take a dealer or locksmith to make you a new key. There's no way around it at home unless you install another mated PCM and SKIM module with mated sentry key. You could also send your PCM to Sykes tuning and have the SKIM turned off. But that's about the same price as having a sentry key made. And it would likely take much longer.
If you still have a sentry key left, you can just have a copy made from a regular blank and then take the sentry key and zip tie it to the SKIM module under the steering wheel column cover. Then you can just use regular keys from then on.
Old 07 Nov 2016, 08:05 am
What Handy said. I only got one transponder key with mine and since there are 3 of us that drive, we were always wondering who had the key. I got keys made at Walmart and zip tied the transponder key to the SKIM under the steering wheel cover. My Walmart keys work like a charm and everyone has their own key now.
Old 07 Nov 2016, 11:29 am
cant i find out the freq. of my key and put the propper amount of resisters to equal , and get by for a miniute ?
or even can i match that freq, any other way ? cell phones ect...
Old 07 Nov 2016, 12:01 pm
Lot's of things are possible if you have the skills and resources. But I've never heard of an easy "trick" to do this on a PT Cruiser. The dealership can take your VIN and look up the SKIM code. Then they unlock the SKIM to mate the new key. I believe locksmiths use this same method and/or use a device to "hack" the SKIM to get the code. There's a U-tube video on that but it takes some pretty expensive locksmith tools and software. As far as I know (and I'm no expert on this), neither dealer nor locksmith actually has a way to determine the sentry key transponder unique frequency. Plus, I believe the key transponder doesn't even use a unique frequency. I believe it sends a code to the SKIM and not just a fixed signal at a specific frequency.
The cheapest route is likely going to be a locksmith that makes house calls. That way the vehicle does not have to be towed. This service is very common in my area and usually runs somewhere between $100 and $200.
Also, if you have them make two separate (not cloned) sentry keys, you can then program more yourself.
Old 07 Nov 2016, 12:18 pm
rob302's Avatar
my locksmith quit reproducing older vehicle keys because various manufacturers were only keeping info on the keys for a set amount of time, for example i believe she said ford was only keeping them 6 years. 16 years is a long time to keep notes. she would still re-key the locks and ignition, but could not find the data on which key to cut.
i wonder how long chrysler keeps key info on file?
Old 07 Nov 2016, 12:53 pm
rsrocket1's Avatar
The locksmith I found locally told me about getting the PIN code and key code from the local Chrysler dealership. If I gave him those, he would cut the key, program the car and test it out for $50.
I went to the local Chrysler dealership with my vehicle registration paperwork and ID and they simply looked it up in the database in Florida (that's where the parts guy said it was located) and got a printout. No charge.
I told the locksmith I had 2 complete FOB's and 2 additional empty key shells. He did the whole batch for $75. When he cut the keys, it was based purely on the key code and he did not need the original key to make the duplicates. They were cut "factory fresh" rather than a copy of an old worn out key.
Here's a more detailed story of my key experience.
Handy_Cruiser likes this.
Old 07 Nov 2016, 01:34 pm
i agree ! this is a bunch of shit ! i own the damn thing and if i want it without all that theft crap then it WONT !
it is on a freq. 90% sure and others found a way just making the freq. near the ignition with enough resistors put together.
i will try to find a way tp do without the whole thing... wish it could just be shut off
and im gonna try to produce a better way using a cell phone....
WISH ME LUCK !
Old 07 Nov 2016, 01:54 pm
I did that with a GM vehicle. Don't know if it required a battery.
In fact I don't know if ours requires a battery in the FOB to work,,, anybody?
rob302 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 07 Nov 2016, 01:56 pm
WISH ME LUCK !
If you do find a way, please share it with us.
But if you do want to just shut it off, here's they guy that can do that.
Dodge Security SKIM Key Disable
rsrocket1 likes this.
Cheap Way to get a new transponder key! thegoldpt General PT Cruiser Discussions 16 17 Sep 2015 10:17 pm
Help with choosing bypass transponder for alarm please Shaggy_gomez Sound and Security Forum 1 06 Dec 2011 11:23 pm
Chipped/transponder key help swordfish Tech & Performance Forum 0 21 Apr 2010 02:56 pm
Column replacement/Transponder Markincali General PT Cruiser Discussions 2 18 Feb 2010 08:37 pm
Transponder Keys Opiate General PT Cruiser Discussions 8 28 Jul 2004 06:58 pm
