knocking noise
Old 06 Nov 2016, 08:05 pm
Default knocking noise
it is a couple of weeks that there is a knocking noise comes from the engine when is in acceleration, but not when is idle, specially get louder when is in up hill and sometimes turns off itself more when backing off. I did changed the sparks and wire and clean the injectors and put high octane, but not much a change. Any idea what would be source of it?
Old 06 Nov 2016, 08:12 pm
Handy_Cruiser's Avatar
Default Re: knocking noise
First, welcome to the forum from the great sovereign state of Arkansas!
You should introduce yourself and tell us more about your PT in the new members section.
To help you, the first thing we will need is information about your PT. What year, what edition, how many miles, stuff like that.
Next, does the knock only happen when going down the road and does it change with the speed of the car or speed of the engine? That might help us determine if the sound is coming from the engine, drive train or suspension. It would also be great if you could post a cell phone video of the knocking if you can.
Knowing nothing more than what you've said, my first thought is a bad CV shaft, and/or a bad motor mount. These will sometimes cause a knocking when the car is under a load. But again, we will need more information to truly help you.
Old 06 Nov 2016, 08:26 pm
rckstein's Avatar
Welcome to the forum
Old 06 Nov 2016, 09:53 pm
Sorry. I am from Toronto, ON, Canada. My PT is 2006, 240k, 2.4 non turbo. As I mentioned when the car is idle there is no noise, but when is accelerating there is this noise which get louder when is in up hill. I do not believe is a engine mount which has been changed recently. It looks like a valves within engine. It is also sometime the car turns off when I am in revers or decelerating.
Old 06 Nov 2016, 09:56 pm
Apparently between 60km/h to 100km/h the knocking is more accentuate, but when you keep the speed constant it goes away unless when it get to some part when the road has steep inclination upward but not downward.
Old 07 Nov 2016, 12:11 am
Do you have a check engine light? And if so, have you checked for trouble codes?
Old 07 Nov 2016, 07:24 am
no check engine light on and the mechanic check and everything were in normal range.
Old 07 Nov 2016, 07:50 am
Welcome to the forum. Have your "mechanic" check the belt tensioner. Sometimes they can lose tension and start popping. They make a hell of a racket. I had one do that on a 3.3 Grand Caravan I had.
Old 07 Nov 2016, 02:28 pm
The problems with mechanic is that they go with exclusion. He thought it was the sparks and wire which I changed and was not an issue. Now he is saying ignition coil, belt tensioner, and or one of the piston is misfiring. which one it is? nobody knows. Naturally if it is a piston, it does not worth fix it?
I have to say that PT Cruiser was disaster of engineering.
Old 07 Nov 2016, 03:45 pm
Dude, you need to find another "mechanic". Sounds to me like that dude doesn't know the difference between his ass and a hole in the ground.
Knocking noise from engine 01n3on General PT Cruiser Discussions 18 20 Apr 2014 08:35 pm
knocking/creaking noise jmont2536 Tech & Performance Forum 2 23 Aug 2011 08:21 pm
Strange Knocking Noise On Start Up frankb General PT Cruiser Discussions 3 28 Oct 2010 08:46 pm
knocking noise from rear Megalon Wheels, Tires, Suspension 5 13 Jan 2008 09:44 am
Knocking noise from rear end Ctown General PT Cruiser Discussions 9 22 Nov 2005 06:08 pm
