Placing rear jack stands
Like Tree4Likes
  • 1 Post By NitroPT
  • 1 Post By NitroPT
  • 2 Post By Carnut
Old 08 Nov 2016, 08:56 pm
JonN's Avatar
Default Placing rear jack stands
Hello,
I have a quick question. I plan to replace the rear rotors and pads in my PT soon. Is it safe to lift the rear up with a floor jack by lifting in the center of the axle and place jackstands underneath both sides of the axle?
Thanks
Old 09 Nov 2016, 03:38 am
Default Re: Placing rear jack stands
Use a board on the floor jack to spread the wieght and you will be fine.
Carnut likes this.
Old 09 Nov 2016, 10:29 am
Goes on the pinch welds where the tire jack would go. They say not to put it on the axle but some say if it hols up the car it will work. I try to play safe.
Mike
Old 09 Nov 2016, 10:54 am
rckstein's Avatar
On the edge of one of the doors is a label, similar to this one, with the lift points:
Old 09 Nov 2016, 11:31 am
It is really hard to place a floor jack on the twist beam axle. The housing of the twist beam can easily support the complete weight of the PT Cruiser.
The previous response diagram is basically for changing tire/wheel on a single axle position and also showing chassis support area for a shop or general 2/4 point vertical lift.
Carnut likes this.
Old 09 Nov 2016, 12:19 pm
LionPT's Avatar
Originally Posted by JonN View Post
Hello,
Thanks
I did it last year when I replaced my rear brakes without any problems.
Old 09 Nov 2016, 05:48 pm
Carnut's Avatar
Yep, floorjack under center of axle and stands at each end of axle worked for me.
NitroPT and chuzz like this.
George H. McDowell
Wichita, Kansas
mailto:carnut@carnut.com
http://www.carnut.com/
FB https://www.facebook.com/george.c.mcdowell
My 2005 PT Cruiser GT Convertible Project
Old 10 Nov 2016, 08:54 am
Fk5 Fk5 is offline
My biggest problem was that my jack stands were too big. If I tried to jack one side, both wheels would be coming off the ground before I could slip one under there. I got a little mini-set and it has been much nicer. I guess that my other cars are a bit heavier and longer.
2003 GT 5 speed
162,000 miles
Clean Out Sale.... ACdelco Jack Stands, eclispe cd player,led mirrors,front headrests outfit Classifieds: For Sale/Trade 0 23 Apr 2009 04:08 pm
Photos of PT in jack stands ?? guguso General PT Cruiser Discussions 1 20 Dec 2007 08:58 am
Jack stands gonzomania General PT Cruiser Discussions 3 04 May 2005 09:00 am
Jack and stands or drive up ramps? nozzano22 General PT Cruiser Discussions 5 29 Jun 2004 10:06 am
ON JACK STANDS PT Chix General PT Cruiser Discussions 12 06 May 2004 01:02 pm
