front end clunking noise
Like Tree2Likes
Old 10 Nov 2016, 12:31 pm
Default front end clunking noise
08 base PT 64K miles
clunking noise when driving over uneven or rough pavement
comes from up front, seems louder on passenger side
both lower control arms complete with ball joints replaced @ 30K
both stabilizer bar links replaced @ 42K
both front struts including top bushing replaced @ 52K
lower control arm bushings, tie rod ends, ball joints, stabilizer bar links and bushings, brake caliper/rotor all look/feel OK
nothing obvious but can hear definite metallic clunk, this noise is similar to that when the LCAs were replaced over 30K ago but they appear to be OK
noise has been present for a while, replaced the front struts last year as it sounded like it could be a bad strut... but did not help
any ideas???
Old 10 Nov 2016, 01:07 pm
JonN's Avatar
Default Re: front end clunking noise
I doubt this answer is the solution to your problem, but it doesn't hurt to check. I had a similar experience and it turned out to be one of the plastic shields being loose and banging around when I went over bumps or uneven pavement.
Old 10 Nov 2016, 04:43 pm
Check the rear bushing on the right side control arm, the bushing mave have slipped, and I had a ball joint that was pressed into the LCA and was held secure by a outside circlip and it was so loose it started to bang.
Check engine mounts too.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 10 Nov 2016, 06:37 pm
Well, spent some quality time under the PT this afternoon pushing, pulling, prying. Found the plastic shield behind the passenger side wheel to be cracked top to bottom but was not the source of the noise. LCA bushings seem OK but did find the passenger side stabilizer bar bushing to have a little play in it. Got a pair of Moog replacement bushings at the parts store but too dark here now to work on it. Will get back on it in a day or two.
Meanwhile, thanks for the replies and will post the results of the bushing replacements.
Old 10 Nov 2016, 07:17 pm
Be sure not to over torque the sway bar bushing bolts and end link nuts. Both torque to 20 ft. lbs. Believe it or not!
Old 11 Nov 2016, 11:05 am
UPDATE
Found the noise source and fixed it !
It was indeed the passenger side stabilizer bar bushing. Replaced both bushings with Moog P/N K80364 bushing kit. This kit fits a 24mm bar which is what mine measured. Amazing to me how such a small amount of play in the bushing (that at first had escaped my notice) caused such a loud annoying noise. btw... thanks for the heads up on the torque specs.
_PTGT03 likes this.
Old 11 Nov 2016, 02:21 pm
Happy to help and happy to hear you solved it relatively cheaply! Happy PT'ing.
Old 11 Nov 2016, 05:09 pm
Glad you found the issue. I had/still have the same noise you're talking about but have yet been able to figure it out..
Changed right side motor mount, 2 new moog strut/spring assembly, 2 new moog complete control arms, sway bar bushings and end links.
Old 11 Nov 2016, 05:53 pm
Are you sure you got the right size sway bar bushings, fox? I had to measure mine to make sure. I have the 24mm bar too.
Old 12 Nov 2016, 12:24 pm
I actually bought all the.. the 22mm 24mm and 26mm ... 24mm matched up exactly as the one on the car
chuzz likes this.
clunking noise front right tire area quenuss Tech & Performance Forum 3 14 Oct 2014 07:08 pm
When going in reverse a clunking noise from front end of car PalmSPringsSunshine Tech & Performance Forum 10 14 Apr 2014 02:04 pm
clunking noise?? Dino General PT Cruiser Discussions 23 23 Apr 2013 01:36 pm
Clunking noise in front RoseDust Tech & Performance Forum 4 19 Sep 2011 10:21 pm
Front end clunking noise discovering06 Tech & Performance Forum 1 26 Feb 2011 07:01 pm
