03 Turbo Power Steering Pump
Like Tree6Likes
Old 10 Nov 2016, 07:22 pm
Default 03 Turbo Power Steering Pump
Today I was changing out the power steering fluid using a flavor injector and the needle that was on the end of the injector came off and went into the reservoir. Is there a screen in the 03 turbo power steering pump reservoir to keep it from traveling around so that it doesn't screw up the power steering pump ? Or do I have to pull the pump to get it out ?
Old 10 Nov 2016, 07:26 pm
Default Re: 03 Turbo Power Steering Pump
I haven't noticed a screen in mine, don, BUT if you have one of the extendable magnets on a stick, you might try that first. Otherwise, I don't know what to tell you.
Old 10 Nov 2016, 07:58 pm
Handy_Cruiser's Avatar
DOUBLE POST
Old 10 Nov 2016, 08:03 pm
I have one, but the needle is not magnetic. I just looked into the reservoir and I can see it. Going to get either a long needle nose pliers or I believe they call them a claw pickup tool
Old 10 Nov 2016, 08:05 pm
Yes,
There is a flat 2x2 inch square screen that sits over the return port.
I just took this photo of the one in my spare turbo power steering pump. You can see part of it. But understand, that screen is on the return side. I don't know if there anything on the pump intake side.
PS: That turbo reservoir is a $200 part. And they are hard to find at salvage yards too. Be careful with yours.
Old 11 Nov 2016, 07:45 am
If you know someone that works in the medical field, you could ask them if they have a long nosed pair of hemostats. I've used those over the years to reach into small places and pull things out. I have a pair of the short ones, but my long ones disappeared years ago. I had an "acquaintance" that was a pot head and I'm pretty sure he grabbed them one day while I wasn't looking.
Old 11 Nov 2016, 10:33 am
LionPT's Avatar
Just put a piece of duct tape on a stick.
Old 11 Nov 2016, 01:07 pm
Solved my problem Gentlemen, went to parts store and picked up a claw pickup tool. Thanks for the suggestions.
Old 11 Nov 2016, 02:02 pm
rob302's Avatar
you mean a toothpaste cap grabber? ie:
Old 11 Nov 2016, 02:09 pm
rckstein's Avatar
Missing the drain stopper in your sink or shower
You just need to use toothpaste with a flip cap that stays attached to the tube
2003 turbo power steering pump with res omnicrazy Classifieds: Want To Buy 1 13 Apr 2016 07:06 am
Power Steering Pump Replacement - 2005 2.4 Turbo Nvizn Tech & Performance Forum 8 21 Mar 2016 03:56 pm
Turbo Power Steering Pump Reservoir Ikster Tech & Performance Forum 0 17 Oct 2015 01:04 pm
need 2003 gt turbo power steering pump and res zipps Classifieds: Want To Buy 1 12 Apr 2015 06:52 pm
Power Steering Pump N/A vs. Turbo meder2487 Tech & Performance Forum 3 13 Jan 2011 10:12 am
