what motor mounts to replace
Old 13 Nov 2016, 01:29 pm
Default what motor mounts to replace
ive got a 2003 pt non turbo with a 5 speed with 134k miles. im almost done doing a clutch swap which I will say is easier that the old style of 3 separate clutch parts.next is the timing belt. I noticed the lower engine mount by the harmonic balancer is tore and old ect . I was wondering what other mounts are there (how many total) . I id like quality parts so what names should I look for?
Old 13 Nov 2016, 02:06 pm
Default Re: what motor mounts to replace
You have three total motor mounts. One right above the one that your looking at and one in the middle of the engine when you facing forward. That's the hardest to get to but might be a lot easier one you start doing the timing belt as the engine has to be slightly lifted to do the timing belt correctly.
HELP! Replace Motor Mounts 2003 Base model howardmims Tech & Performance Forum 5 19 Jul 2014 05:26 pm
Looking To Replace Either Fan Motor Or Fix Motor If Possible - Anybody BTDTGTBT... scoleman69 Tech & Performance Forum 8 22 Dec 2013 05:33 pm
motor mounts 06ptvert General PT Cruiser Discussions 5 07 Jan 2013 02:58 pm
Motor mounts saldagus Tech & Performance Forum 6 15 Apr 2009 09:06 am
motor mounts? 2004PTCruiser Tech & Performance Forum 0 31 May 2008 04:50 pm
