Engine sounds like Diesel on cold start - engine clacking until warm
Old 17 Nov 2016, 10:04 am
Default Engine sounds like Diesel on cold start - engine clacking until warm
I have a 2005 PT crusiser (non turbo) that sounds like a Diesel clacking away until the engine gets warm. Any ideas on a fix would be great.
It started around 90k miles and I have 110K on it now. Automatic.
Video of engine sound: https://youtu.be/ixYid9TeVVM
Old 17 Nov 2016, 01:52 pm
thecabinguy's Avatar
Default Re: Engine sounds like Diesel on cold start - engine clacking until warm
Do you maintain the oil changes on time? Do you use any heavier oil than the recommended 5W30?
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 17 Nov 2016, 03:57 pm
Changed timing belt yet?
Old 22 Nov 2016, 08:27 am
Timing belt has been changed (around 107,000). Yes, oil (5w 30) changed every 3k miles. It started drinking 1 quart of oil every thousand miles (replaced the PCV valve like some suggest).
When the timing belt was changed, I had them change the valve cover gasket - I don't see any oil drip.
Old 22 Nov 2016, 11:55 am
Here is a thread that talks about a service bulletin to modifying the bearing caps:
"Help Identifying Source of Rattle Near Timing Belt"
Here is a link to a SB and images
TSB #: 09-007-04
Torque specs
Old 22 Nov 2016, 11:56 am
Here is a thread that has video and explanation of my exact situation:
Old 22 Nov 2016, 12:31 pm
A bit of info from another forum: "Engine Noise"
Mostly chatter about oil type.
Old 22 Nov 2016, 12:36 pm
Pictures of the modified Cam bearings:
Cold start ticking (video) - Dodge SRT Forum
Old 22 Nov 2016, 12:53 pm
Try to use some MARVEL MYSTERY oil in both your fuel and oil? Also use a quality fuel like Chevron or Shell for a while.
You mileage is sufficient enough that you may simply have normal varnish build up.
IMO Posting all those videos makes helping you all the more troublesome, I would at least try to post one of your own engine. If you do keep the camera in one position because moving it around on a video changes to many sounds from directional to none directional.
Timing belt noise (PT Cruiser specific) is another story. If it does make noise cold and quiets as the engine warms than there may be concern for worn,wearing abnormally or damaged parts.
Old 22 Nov 2016, 03:15 pm
SPLNeon's Avatar
Sounds like it's loose enough for a big shot of nitrous lol
I'm kidding. I have a 2.0 in my winter beater neon that sounds like a vw diesel at idle and it never goes away. This being my beater car, it doesn't bother me and it sees WOT pulls daily. Now my motor is different and I've never heard the 2.4 knock like this. On a side note, I'm getting what feels/sounds like valve float right before red line lol
Fastest fwd PT Cruiser in Canada
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.89at 115mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
cold start - clicking or clacking noise 07ptclassic Tech & Performance Forum 2 12 Sep 2016 09:54 am
engine hick-up when warm area49 General Turbo Discussions 13 07 Jul 2016 12:17 pm
AC blowing warm air and engine studder at idle? cme4tv General PT Cruiser Discussions 3 02 Sep 2013 10:39 pm
Diesel (CRD) Engine Identification Number c13ckb Tech & Performance Forum 7 14 Feb 2010 08:35 pm
Diesel (CRD) Engine identification number. c13ckb Feedback and Support 2 13 Feb 2010 12:46 pm
