General loom wiring, routing question; disassembler's experience needed!
Old 20 Nov 2016, 11:50 am
Prostheta's Avatar
Default General loom wiring, routing question; disassembler's experience needed!
Hopefully this will be a simple question in terms of a straight answer! Anybody that's come across my overhead console refit thread will know that I need a 5v supply for the electronics which means converting the 12v ignition supply down. Space is at a premium in there, plus a voltage converter tends to be noisy and/or have magnetic things in there which will play merry hell with my compass.
My solution is to move the 12v to 5v converter upstream and insert it further into the loom, elsewhere than the overhead console.
Question is, what is the directional routing of the loom? I presume that it goes across the roof in one direction (left towards the internal fuse box?) and down the A pillar or similar. Input from anybody that has had the headliner apart or worked on this area and knows the loom routing has the opportunity to win some Internet Points for this info or even ideas on where to locate a small voltage converter.
Cheers!
2001 2.0l PT Cruiser Touring Edition
Mods: New gear knob, blue LED re-lighting, token chrome bits.
215'000km (55.9% distance to the moon, 71.7% of a second at light speed, Usain Bolt running for 200 days)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use" - Søren Kierkegaard
"What can be asserted without evidence can be dismissed without evidence" - Christopher Hitchens
Wiring guru's needed. pluminator Sound and Security Forum 1 06 Feb 2014 11:10 pm
Wiring guru needed turbomangt Sound and Security Forum 3 01 Aug 2005 08:52 pm
Amp wiring advice needed... Beacon Sound and Security Forum 2 23 Oct 2003 11:11 am
guage wiring help needed Punch Interior Accessories Forum 3 27 Sep 2003 05:19 pm
Wiring Info Needed GTPT General Turbo Discussions 3 15 May 2003 11:01 pm
