Engine won't shut off!!!
Like Tree5Likes
  • 1 Post By CREWZIN
  • 1 Post By rob302
  • 1 Post By rob302
  • 2 Post By DroptopPTGTCruizer
Old 20 Nov 2016, 06:21 pm
Default Engine won't shut off!!!
2001 PT Cruiser Limited. Aprox 65,000 miles. Key will not shut off engine! As this was happening the Check engine light came on?? After trying for about 10 mins., I was able to turn it off. By this point I began to unhook the battery as it was running in garage. Tried the other key,same thing, will not shut off!! Any Ideas??? I know the multi-switch was acting up a couple of years back so I don't have fog lights etc. I was going to replace it but never got around to it. Thanks for any suggestions!
Old 20 Nov 2016, 06:26 pm
Default Re: Engine won't shut off!!!
There's been some problems reported with the ignition switch.
tikitoride likes this.
Old 20 Nov 2016, 06:44 pm
rob302's Avatar
You very likely need a new "ignition switch actuator"
Old 20 Nov 2016, 06:46 pm
rob302's Avatar
Here: ignition switch wont turn to start postion
More
https://www.google.com/search?q=site...ctuator+dorman
Old 20 Nov 2016, 07:18 pm
Thanks Guy's, Good thing it happened at home. Ignition switch actuator? Sounds like If I had some time and patience I could fix myself. Afraid to take it to the dealer but it sounds like I might have to! I work as a shuttle driver for Volvo and I see how they rip people off every day and I really feel for the customers!! Ykes!
Old 20 Nov 2016, 07:43 pm
rob302's Avatar
The dealer will sell you a new column, not just the $34 part. You can do it at home.
Old 21 Nov 2016, 12:31 am
_PTGT03's Avatar
if you can't help yourself you shouldnt be asking on an internet forum just get the work done at a dealer
Old 21 Nov 2016, 01:12 am
Maybe you might have a friend who knows of a good reliable mechanic who works on PT Cruisers.
Old 21 Nov 2016, 02:50 am
DroptopPTGTCruizer's Avatar
SERIOUSLY???? What the hell kind of a response is that?? You have been a member on this forum for over a year, would have to assume you know how these automobile internet forums kinda work?? People ask questions when they have a problem with their car they can't figure out..... then others provide responses usually "helping" the individual asking the question get pointed in the direction of a resolution to their problem or issue.... pretty much how it works.
CREWZIN and chuzz like this.
2005 PT GT Convertible HO Turbo Autostick ~ black/black leather ~ 53,000 miles ~ summer-only driver ~ OEM rear sway bar ~ K&N 57 series CAI ~ 4-wheel ABS ~ Hawk Sector 27 drilled/slotted rotors ~ Hawk Performance Ceramic pads ~ Firestone Firehawk Indy 500 Wide-Oval performance tires ~
2003 PT Cruiser 2500 RPM Limit/Engine Shut Down tejones Tech & Performance Forum 10 24 Jun 2015 04:23 pm
Engine shut off while driving. No codes Twoscoops2 Tech & Performance Forum 7 21 Jan 2014 07:24 pm
pt blowing fuse to shut off engine ? bruinspt Tech & Performance Forum 2 23 Jun 2009 10:32 pm
Engine Shut Off, Will Not Restart Stevearino Tech & Performance Forum 37 18 Oct 2007 11:55 am
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
