2003 turbo power steering and ac belt tensioner
Like Tree3Likes
  • 2 Post By rob302
  • 1 Post By rob302
Old 27 Nov 2016, 05:51 pm
Default 2003 turbo power steering and ac belt tensioner
How do I get this belt tensioner bolt out? There's no room for a ratchet or any thing. barely got the pulley bolt out. Now I have a new tensioner with pulley but I have to disassemble the new tensioner/pulley in order to mount it back on the motor I don't have a vice grip to hold the tensioner tight when I loosen the pulley. also struggling with that
Old 27 Nov 2016, 06:04 pm
rob302's Avatar
Default Re: 2003 turbo power steering and ac belt tensioner
ha! yeah! bolt hits the frame. i remember that. annoying, isn't it?
i had that issue when i was trying to take just the pulley off.
you're removing the bolt marked 2, not the one in the center of the pulley, correct? bolt marked 2 fits out.
as for moving the tensioner, i just used my hand. it's only 35-45lbs of tension
Old 27 Nov 2016, 06:06 pm
rob302's Avatar
i think a ratchet with a deep socket is the perfect length to clear the tensioner yet fit in there
cloudhidd3n likes this.
Old 27 Nov 2016, 07:04 pm
Okay I got it here is what I did first removed old pulley and the Bolt and then the tensioner bolt I have to get it at an angle with a box wrench so I got the tensioner out now I lined up the new tensioner it with my fingers put the bolt in as far as I could. Then withthe new tensioner on and tightened slightly I had to remove the new pulley of the new tensioner so I can make room to further tighten the tensioner bolt and then I put the new pulley back on and done. After all said and done the noise the whole way I figured out is the alternator that's making the noise god dammit
Old 27 Nov 2016, 10:36 pm
Okay I'm going to change the alternator belt problem though I loosened both mounting bolts and the tension adjusting bolt on the alternator but the alternator isn't moving it's stuck in the same position and barely came loose any ideas how to get alternator to budge to move so I can remove the belt thank you
2003 turbo power steering pump with res omnicrazy Classifieds: Want To Buy 1 13 Apr 2016 07:06 am
need 2003 gt turbo power steering pump and res zipps Classifieds: Want To Buy 1 12 Apr 2015 06:52 pm
Changing power steering belt tensioner.... Alltorque1983 General PT Cruiser Discussions 6 19 Mar 2015 03:28 pm
Power Steering Belt tensioner pulley problems Bandit2014 Tech & Performance Forum 11 04 Jan 2015 01:47 pm
a/c power steering belt tensioner swanjack Tech & Performance Forum 6 13 Apr 2011 06:51 am
