Speedo/Tach Light Issues
Like Tree3Likes
  • 2 Post By rob302
  • 1 Post By _PTGT03
Old 27 Nov 2016, 06:01 pm
Gkon's Avatar
Default Speedo/Tach Light Issues
Hi all,
When I bought my PT in June 2015, some of the light bulbs for the speedo and tach were burnt out so I replaced them with LED's.
Since then, a few months ago one of the LED's started to flicker. I chalked it up to a faulty LED and replaced it with a new one from the same batch I bought when I initially swapped them out.
Two nights ago I noticed that now yet another of the bulbs is flickering.
What gives? I have to wonder if the problem is with the these LED's or if the problem is with the PT's gauge cluster as some stock bulbs were burnt out when I first bought it.
Any suggestions on how to find out, or any info about these gauge clusters having issues?
Thanks.
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 27 Nov 2016, 08:21 pm
rob302's Avatar
Default Re: Speedo/Tach Light Issues
yep. me. i put bulbs back in mine. if they burn out in another 10 years THATS FINE!!
there's a few possibilities.
1- whomever made them chose a resistor value that would illuminate brightly at 12v. unfortunately at 14v, they are slightly overloaded and slowly fail
2- the cheap ebay LED's that i bought had so little solder to attach the resistor to the lead of the LED, they break off, from vibration, heat, etc, and they flicker and quit illuminating. this happened to me..one by one. after a month or two, i couldnt even see the dash
3- (see pic) the bases on most of these are hollow all the way to the bottom divider. this way there is room internally for the resistor. unfortunately, the way they are installed the + and - can touch. the bulb in the upper right here is how close they were in the base i'm holding. i noticed the problem with these because the first one it tried failed to light up.
Old 27 Nov 2016, 08:27 pm
rob302's Avatar
better pic of how close the + and - are inside the base, and where they're soldered. corrosion shown is just a bonus. this bulb as never been outside of my shop
these are the white base ones.
the LED's that fell apart on me were a pink base. literally the resistors just fall off. no pictures of those, i got pissed and threw them all away
idk if any of that helps. take one apart!!
Handy_Cruiser and Gkon like this.
Old 27 Nov 2016, 09:15 pm
_PTGT03's Avatar
Originally Posted by Gkon View Post
Hi all,
Thanks.
be careful to notice if any other lights are flickering like the overhead console or the head lights. this indicated the voltage regulator which is built into teh PCM is going bad and either live with it or replace the PCM completely.
Gkon likes this.
Old 28 Nov 2016, 08:29 am
Gkon's Avatar
Good point _PTGT03. Thankfully, no other lights flicker. All is steady.
The only issues is with the gauge lights.
2005 turbo light speedo markings racerev PT Cruiser Convertible Forum 4 01 Feb 2016 04:55 pm
RED LIGHT IN SPEEDO?? drumrooster Tech & Performance Forum 1 20 Jul 2011 08:17 am
Speedo & Tach jumping when engine is turned off. ShayP Tech & Performance Forum 1 20 Jun 2011 12:46 pm
Tach, Speedo & gas gauge not working?! mothersonion General PT Cruiser Discussions 2 15 Sep 2008 09:12 pm
tach'd up & the "brake light" flashes Hedgapple General Turbo Discussions 4 03 Jul 2007 09:50 pm
