Strange coolant loss
Like Tree10Likes
Old 29 Nov 2016, 12:05 pm
FeelthySanchez's Avatar
Default Strange coolant loss
on Mamma's 2001 LE as follows, which has a long history of this condition.
Details:
259,xxx on odometer.
Orig engine was "overhauled" @ 174,xxx.
New radiator 2 weeks ago, & it's sealed solid.
No obvious viscous leaks. Anywhere.
Random P0300, which comes & goes.
Spark plugs appear normal for a high-mileage engine.
The oddest feature here: it loses MUCH LESS coolant when the heater is turned on. Once this odd fact was noted, I advised her to "run the heater constantly".
Typical scenario: after a 14mi round trip commute to/from work, the upper tank & overflow bottle will frequently take 1.5 gal total. Shorter hop losses are proportional.
I've trained her to keep a good eye out for any pooled liquids, & always keep a large filled water bottle & funnel handy.
Thus, given the above info ...... could one of you fine gents offer-up any possible insight as to what the heck might be going-on?
Many tnx !!
Phil T.
Orig owner 100% stock Patriot Blue 2001 LE 5-spd: 283,760 miles & rolling well on it's 3rd ECM, 2nd engine, 3rd gearbox, 2nd rack & pinon.
"The idiot's guide to passing yourself off as leadership" - Ed Hipalito. Author, mgmt failure, narcissistic buffoon.
Old 29 Nov 2016, 01:22 pm
VsandFords's Avatar
Default Re: Strange coolant loss
It would be a good idea to have the system pressure tested. There has to be a leak somewhere, possibly the head gasket. It sounds odd but, there is a chance that the water is getting into a cylinder or two. As far as turning the heater on to help, unless it's a temperature thing, when you turn the knob to the red side, you are only moving a blend door. The water is always running through the heater core.
A gallon and a half in a 14 mile span is an extreme amount of coolant loss in my opinion. Especially if you do not see steam, have a puddle or a trail of coolant.
Do a coolant pressure test.
Old 29 Nov 2016, 01:54 pm
If you are observing low coolant levels after running the vehicle you do not have a closed/sealed system.
I recommend to do a pressure test and carefully examine all the hoses and caps.
If you do not find any leaks than you should do a block test to confirm no coolant in the cooling system.
The heater on a PT Cruiser is constant coolant flow. When to adjust setting you are only opening and closing air flow doors.
VsandFords and Gkon like this.
Old 30 Nov 2016, 11:06 am
Many thanks to both of you gents, as these answers have confirmed my thoughts.
Will schedule a pressure test as suggested on the next maint interval (due in ~3 weeks).
Regarding yesterday's 14 mi commute: no coolant loss at all .........
Old 30 Nov 2016, 05:10 pm
I would suggest checking under the engine for dried coolant dripping off the engine. It will show up as a gray dusty film and you might see where the coolant is leaking from. Check and see if you might have the gray dusty film under the water pump area or any area where coolant might leak. As NitroPT says do the coolant pressure test if its not obvious where the coolant leak is coming from.
Are you blowing white smoke?
Old 30 Nov 2016, 10:54 pm
Steve,
Tnx for the reply. We've never noted white smoke from the exhaust.
Old 30 Nov 2016, 11:13 pm
REPEAT!! ^^^^^^^^^^^
Old 30 Nov 2016, 11:26 pm
You can buy an coolant pressure tester for a reasonable price at Harbor Frieght.
Search results for: 'coolant pressure test'
NitroPT likes this.
Old 05 Jan 2017, 09:04 am
Default Re: Strange coolant loss (a no-brainer)
Well, many tnx again.
Happy to report that the lower hose had an obvious ring of crusty coolant residue from a permeation leak: the worm-drive hose clamp was loose by 1.5 turns.
Handy_Cruiser likes this.
Old 05 Jan 2017, 09:17 am
rckstein's Avatar
Glad to hear you got the issue fixed, but worm-type clamps should not be used as they apply unequal pressure on whatever they are clamping, it's best to use the original type spring clamp.
Strange timing belt failure and other strange symtoms StephenB Tech & Performance Forum 5 28 Mar 2016 12:57 pm
Major Coolant Loss Digboy78 General PT Cruiser Discussions 14 29 Jan 2016 03:38 pm
Leaking coolant - "Engine coolant pipes"? xkey General PT Cruiser Discussions 3 01 Jun 2014 09:11 am
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
2001 coolant loss mystery zip Tech & Performance Forum 40 29 Jan 2013 01:17 pm
