Maintenance Interval chart from Owner's manual.....
Old 29 Nov 2016, 06:12 pm
rockandroller's Avatar
Question Maintenance Interval chart from Owner's manual.....
Um... I'm checking on what is coming up... but a couple of these seem a bit ODD (marked in red below)
Check Brake linings 32,000
Flush Brake Fluid 30,000
Flush Radiator Fluid 96,000
Flush Transmission Fluid 30,000
Fuel Injector Maintenance 30,000
Replace Air Filter 48,000
Replace Fuel Filter 30,000
Replace PVC makeup filter 48,000
Adjust generator belt tension 48,000
Inspect tie rod ends & boots 48,000
Check Alignment 60,000
Differential Oil Change 60,000
Replace PCV Valve 60,000
Comments??
2004 'Turbo Lite'
Old 29 Nov 2016, 06:19 pm
rob302's Avatar
Default Re: Maintenance Interval chart from Owner's manual.....
..dp..
Old 29 Nov 2016, 06:22 pm
rob302's Avatar
obviously a very generic list geared towards a RWD car that has a fuel filter. that's in your owners manual? LOL
what mileage are you at?
Old 29 Nov 2016, 06:27 pm
rob302's Avatar
from alldata:
Old 30 Nov 2016, 01:00 am
Thanks! I put that into a tracking spreadsheet a couple of years back, and must have taken a generic one and padded it with some numbers from the manual ( then forgot to delete the stuff that wasn't in the manual...)
SO there is no differential, and we can forget about pulling the fuel tank every few years ?
2004 'Turbo Lite'
Old 30 Nov 2016, 08:13 am
Fuel injector maintenance??
Old 30 Nov 2016, 08:23 am
rckstein's Avatar
He mentioned he took that info from a "generic" maintenance plan. In addition to throttle body cleaning, which some shops do on or off the vehicle, some shops recommend and do an injector cleaning service, which introduces cleaning chemicals in the fuel system. Is it worth it and do they really work or are they more effective than just using good quality fuel or adding a bottle of fuel additive periodically to the tank is probably open for debate.
Old 30 Nov 2016, 08:28 am
I'd say it's open for debate. I have never had an injector problem. I run a bottle of Techron Fuel Injector Cleaner through my tanks about every 10,000 miles. I've had vehicles go well over 200,000 miles without any injector problems at all.
Old 30 Nov 2016, 08:44 am
rckstein's Avatar
A few years ago, when gas prices were real high, I started using Murphy (Walmart) fuel, because it was much cheaper. Others will probably want to argue, but I'm convinced their fuel killed the O2 sensors on my PT, and it ran like crap. Replaced the sensors and have only used name brand (Shell, Texaco, etc) fuels and have not had any fuel problems since. Once in a while I might run a bottle of a fuel additive through the tank.
Old 30 Nov 2016, 09:48 am
Originally Posted by rockandroller View Post
SO there is a differential,
It is in the transmission. So technically that one would still be accurate.
cooling fan chart in shop manual momride General PT Cruiser Discussions 12 24 Jul 2015 03:56 pm
01-04 Maintenance Manual southtxcruiser General PT Cruiser Discussions 0 15 Jul 2015 09:23 pm
2003 PT Cruiser 101K 5-speed manual Great Maintenance - Philly - $3,100 sm0421 Classifieds: For Sale/Trade 20 04 Mar 2012 08:50 pm
Maintenance Manual Merlin1 General PT Cruiser Discussions 2 16 Sep 2010 08:46 pm
Which maintenance manual rogert General PT Cruiser Discussions 6 05 Sep 2010 08:35 pm
