2007 PT Cruiser fuel pump relay location?
Old 30 Nov 2016, 11:45 am
gr82knowme's Avatar
Default 2007 PT Cruiser relay location and descriptions?
Suddenly my car would not run. Battery good, and I can hear fuel pump turn on. But seems like its not getting gas. Turned over and stalls instantly many times. Did start when sprayed but cuts out quickly. Had it towed to house. Now it doesnt start but keeps trying to turn over. 2007 schematic is hard to find.
Can anyone tell me what these 6 ( 4/2) relays control? If one is the horn, I could switch over to see if the other is faulty....BUT I CANT EVEN REMOVE....
setup similar to other posters pic...
Last edited by gr82knowme; 30 Nov 2016 at 01:38 pm. Reason: changed title question
Old 30 Nov 2016, 11:54 am
LionPT's Avatar
Default Re: 2007 PT Cruiser fuel pump relay location?
There is no fuel pump relay in the G2's 2006-2010.
Did you by chance change something with the ignition or keys..??
It sounds like the 2 sec. theft cutoff.
Old 30 Nov 2016, 11:59 am
gr82knowme's Avatar
I actually thought of that too but my remote has never worked, or at least i put a new battery in and it would not lock/unlock the car
Is there a way to disable? I dont think the car even stayed started 2 seconds. I had similar in a jeep gc once. My vin # is *********** ...is that a G2?
Old 30 Nov 2016, 12:24 pm
gr82knowme's Avatar
oh great, kinda did what another thread talked about with off/on/off/on method....now car won't even start. Or maybe it had something to do with me finally being able to pull out the last box on right in the set of 4? But I reconnected and although there is battery power to car, it won't even attempted to start.
Old 30 Nov 2016, 12:50 pm
rckstein's Avatar
Is there a way to disable? I dont think the car even stayed started 2 seconds. I had similar in a jeep gc once. My vin # is ...is that a G2?
Welcome to the forum
From your VIN your PT is a 2007 which is considered a Gen2.
FYI, you might want to remove the VIN from your post to get such private/personal info from a public forum. Someone could use it for unscrupulous deeds.
Old 30 Nov 2016, 01:05 pm
gr82knowme's Avatar
based off the picture in the beginning post...could you tell me what those 6 black cube, relay looking parts are?
Old 30 Nov 2016, 01:09 pm
rckstein's Avatar
I don't see a pic in the first post. I'm on my phone, but I used 2 different browsers and don't see a pic.
Old 30 Nov 2016, 01:28 pm
gr82knowme's Avatar
here is the picture(s) as attachment
File Type: jpg 15301259_1170237206396976_628100469_n.jpg (70.0 KB, 27 views)
File Type: jpg 15302310_1170237053063658_1222945790_o.jpg (91.1 KB, 25 views)
_PTGT03's Avatar
for looking up a carfax ?? are you serious
Old 30 Nov 2016, 01:44 pm
LionPT's Avatar
The 1st pic is your PCM...the computer
the 2nd is the Auto Shutdown & Starter relays.
Fuel pump and relay Pthobbit Tech & Performance Forum 4 28 Feb 2016 10:39 am
fuel pump relay izcom2002 General PT Cruiser Discussions 7 31 Jul 2014 04:39 pm
2006 PT Cruiser Fuel Pump Relay Sweaty_AZ Tech & Performance Forum 2 09 Jun 2014 08:11 pm
fuel pump relay jc1200 General PT Cruiser Discussions 1 23 Feb 2013 01:16 pm
Fuel Pump Relay Location 06 PT goboom2 Tech & Performance Forum 0 17 Dec 2011 03:13 pm
