Why does my engine sound like this on cold mornings?
  • 1 Post By NitroPT
Old 07 Dec 2016, 02:01 pm
Default Why does my engine sound like this on cold mornings?
Here is a video of the sound:
https://youtu.be/ixYid9TeVVM
Any ideas?
Old 07 Dec 2016, 02:14 pm
Default Re: Why does my engine sound like this on cold mornings?
I recommend to go get a new batter. Or at least get a proper load test on that one because it is really working hard. Clean the battery cables at the battery and the body ground.
The DIY first thing is to get a bottle of Marvel Mystery oil and add the complete bottle to the oil. DO NOT remove any engine oil. Than when you are no more than 1/4 tank of fuel go to a Chevron only and fill your fuel tank. Drive for a 50-75 miles, no more than 150 miles and change the oil and filter. Do not add any other fuel or oil additives.
If the noise starts to subside on cold morning starts repeat the above a couple more time. Chances are if you are lucky only varnish has accumulated on the valve train and other internal engine parts.
Otherwise it time to get out all the test equipment and start an engine health evaluation. Compression, leak down, block test etc,.
Old 07 Dec 2016, 04:18 pm
I would add to the above to use synthetic oil. It's like chicken soup, it can't hurt.
Engine sounds like Diesel on cold start - engine clacking until warm mr_mahoney General PT Cruiser Discussions 30 04 Dec 2017 04:12 pm
Engine makes a sound when turning off the engine. Leroy Sound and Security Forum 8 12 Apr 2015 08:56 pm
Does My PT's Engine look/sound okay? Youngmaninanoldmanscar General PT Cruiser Discussions 9 08 Jan 2013 11:39 am
Cold Air Intake Sound cruizer8 Turbo Performance 32 20 Jan 2010 09:04 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
