Headlight question or observation
Old 09 Dec 2016, 07:48 pm
loomex's Avatar
Default Headlight question or observation
On most cars I see with a 4 headlight system, when you turn on the high beams, the low beam lights turn off. On my 02 cruiser, I discovered the low beams stay on when I hit the high beams. Is this the norm?
"Christine", a 2002 (manufacture date 8/2001) base model, 2.4L 5-speed.
USAF 83-92, IRR 92-94, NV ANG 94-98, IRR 98-00
Old 09 Dec 2016, 08:01 pm
rckstein's Avatar
Default Re: Headlight question or observation
On my PT, if I have the headlights on or off, if I pull back on the light stalk, the high beams flash, but if I push the light stalk forward, with the headlights on, then the low and high beams will all be on.
Old 09 Dec 2016, 08:04 pm
YES
headlight question
Old 09 Dec 2016, 08:35 pm
rckstein's Avatar
With my PT, the fog/driving lights were added by the dealership, but as explained in the thread that QSD provided, mine do not cut off if I have the headlights on, and also push the light stalk forward to activate the high beams, all the lights stay on.
Old 09 Dec 2016, 10:17 pm
loomex's Avatar
Well, at least it's normal for the car.
Old 10 Dec 2016, 11:14 am
rob302's Avatar
that's probably a significant factor in why connector C103 melts under the dash.
TV Ad observation....PT Dreamer pasadenahotrod03Dreamer Wheels, Tires, Suspension 4 31 May 2014 10:23 am
headlight question 1AZPT General PT Cruiser Discussions 7 30 Apr 2014 07:50 pm
Headlight Question Kittera Exterior Accessories Forum 8 01 Dec 2013 09:53 am
headlight question Wonderjava Exterior Accessories Forum 1 19 Sep 2012 04:03 pm
