Leaking coolant from this?
Old 10 Dec 2016, 03:36 pm
Default Leaking coolant from this?
I have a PT Cruiser 2005, no overheating problem but i do smell coolant in the car and in the engine comparment, the smell is not sweet as other people have described. Can anyone identify from the image what this is that is leaking?
Thanks
Old 10 Dec 2016, 03:46 pm
Default Re: Leaking coolant from this?
Not sure about the leaking question but on your second picture...
Are you asking what the line is for or what the metal bracket is for?
The line is the fuel line and the bracket is to hold that fuel line away from the A/C line because in the early PT's, the fuel line rubbed against the other line and actually caused the fuel to leak causing engine compartment fires.
On the other question, I found this so hopefully it will answer your leak question....
Fuel Line Leaks- Look at your PT
Old 10 Dec 2016, 03:57 pm
Thanks for the quick reply, so it is a fuel leak.
Is that a fuel filter at the end of the line?
Thanks again
Old 10 Dec 2016, 04:26 pm
rckstein's Avatar
Welcome to the forum
Old 10 Dec 2016, 04:32 pm
Thanks again
That's not the end of the line, it's just a junction in the fuel line between the fuel tank and the injectors. Might be a small fuel filter but the main fuel filter is inside the fuel tank itself.
Old 10 Dec 2016, 06:21 pm
I found this link
Thanks for everyone's reply.
Leaking coolant - "Engine coolant pipes"? xkey General PT Cruiser Discussions 3 01 Jun 2014 09:11 am
Radiator leaking coolant. NicksCruiser Tech & Performance Forum 7 26 Oct 2012 11:13 pm
Coolant Leaking near Tranny helpless Tech & Performance Forum 16 30 Jun 2012 06:22 pm
2001 PT leaking coolant WildBill1988 Tech & Performance Forum 20 08 Oct 2009 09:30 pm
leaking coolant near transmission pan pppt03turbo General Turbo Discussions 8 19 Feb 2008 02:14 pm
