PT Cruiser Forum Car Videos
Car Rims
Turn Signals Not Working
Old 20 Jun 2004, 07:41 pm
Indynick Indynick is offline
Default Turn Signals Not Working
Both Left and Right Turn Signals not working. Brake lights work. No Turn Signals lights on dash. Looked in the owners manual, and service manual, for the fuse, and no joy. The inside and ouside fuse panels show no fuse for Turn Signals. Service Manual says that the 4-way and Turn Signals both use the same flasher unit. The 4-ways work. Is the fuse inside the flasher? [xx(]
Old 20 Jun 2004, 09:15 pm
MichaelDay MichaelDay is offline
The combination flasher unit gets power from two different sources. At least on the '03 models, the hazard warning get power from Batt while the turn signals get power from the RUN-ACC Fuse 15. That is how the hazard warning can operate with the switch off but the turn signals can't.
To clarify: there are no fuses in the flasher units. Fuse 15 powers the turn signals and the wipers (front and rear). If fuse 15 is blown your turn signals will be out as will your front and rear wipers.
Old 20 Jun 2004, 09:47 pm
Thanks for the info. I will give it a try.
Old 20 Jun 2004, 11:13 pm
That did the trick. Thanks. [8)]
Old 20 Jun 2004, 11:17 pm
If it isn't the fuse, could be the switch. The blinker module usually fails on only one side - left or right, not both. The blinker module can work 4-way and not work for direction.
By the way, Thanks for signalling - seems we're in a minority...
Old 21 Jun 2004, 02:42 am
Jimbo Jimbo is offline
I agree Don, most people wouldn't even know if their
turn signals weren't working
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 21 Jun 2004, 05:14 pm
jmack jmack is offline
Send a message via AIM to jmack
I can actually help in this! My 01 does this from time to time. I knew that the fuses were linked with the hazards, so i just depressed the hazard button once and then released it. It works every time. I am sure there is some technical problem that causes this, but my philosphy is that if that works every time, then oh well.
About to start work on modding my car and making it look even better than it already is!
Old 15 Sep 2004, 12:03 pm
Puck Puck is offline
Interesting but no help in my case. The turn signals on my 01 have failed to work 3 or 4 times over the 3 1/2 years I've had the car. There is no apparent reason and in all cases they have started to work on their own in an hour or two. The hazards continue to function, the wipers still work, but the left and right signal lights do not work -no clicking, no arrow indicator, and of course no flashing lights. It must be an intermittent problem in the switch controlled by the lever. Depressing the hazard button doesn't help start them again. Working the lever a few times sometimes helps, but mostly they just start working on their own. I was hoping it would fail and get fixed under warranty but it always has fixed itself before I could get to the dealer. Last occurance was last Sunday. I thought, "You just had to wait to fail until it was on my ticket, didn't you". Then they started working again and are still good. It's a bit of a nuisance because I never know when they will fail!
Old 15 Sep 2004, 02:22 pm
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
On your bulbs do you use electrical grease. Could stop corrosion that could be giving you a ground also check your battery ground cable. Mine did this and I wiggled the ground cable and retightened hasn't happened since.
Gonz
Old 15 Sep 2004, 02:25 pm
pt_from_ct pt_from_ct is offline
Mine did that for the first time last month. Worked fine on the right side but nothing on the left. They seem to be fine now but i noticed my hazards only flash in the front not the rear anymore and do not light up on the dash.[:I]
http://ptcw.truckmoxie.com/mygallery.ten?id=3466
vB code is On
Rear turn signals? thegoldpt Non-PT Discussions 5 13 Jan 2006 11:22 am
PT turn signals (or lack of) dgranros Tech & Performance Forum 5 18 Mar 2005 11:06 am
Help with Stealth turn signals toplessPT Exterior Accessories Forum 4 16 Mar 2005 10:43 am
Turn signal & stop light gonzomania General PT Cruiser Discussions 12 25 Apr 2004 01:18 pm
Intermittent Turn Signals Puck Interior Accessories Forum 2 11 Aug 2003 07:47 pm
  Internet Advertising | Cheap Magazines | Personals | Remortgages | Mortgage
