pt cruiser 2010-2016 repair list
Old 12 Dec 2016, 10:50 am
Default pt cruiser 2010-2016 repair list
Hi all,
I have a 2010, ~60k miles, and tried to keep track of most of the repair work done since i got it. I figure this might be interesting to some, and i'd like to compare my experience to others. I had an extended warranty which ended up paying off. Bushings and rotors tend to only last me about two years or so, which surprises me, but it might be the Canadian winter climate.. maybe?
pt cruiser 2010-end of 2016
Satellite radio replaced, driver window button module, power driver seat module replaced, tie rod links, bushings (lower control arm, front table, engine mount, about every two years). one wheel bearing, rotors (about every 2 years), oil pan sweat, power steering sweat, leaky PCV valve, replaced shifter shaft (became hard to shift due to rust), back passenger caliper, replaced handbrake shoe, condenser o-ring for the A/C due to leak, leaky radiator replaced, radiator fan motor replaced, voluntarily changed timing belt water pump and all drive belts, two battery changes.
Old 12 Dec 2016, 11:17 am
Default Re: pt cruiser 2010-2016 repair list
Compare:
2001 - 2016 , 122,000 miles
Radiator fan. Camshaft wiring repaired. Polyurethane bushing kit for everything underneath the car. Front disk pads and rotors. New tires all around.
Still original: Camshaft and crankshaft sensors. Front wheel bearings. Multifunction switch.
Old 12 Dec 2016, 03:02 pm
2005 129,000+ miles
Front brake caliper replaced (it stuck)
2 ABS wheel sensors (2 different times)
tie rods
replaced timing belt, water pump, etc, at around 90,000 miles, had auto trans flushed at 50,000 and 90,000 miles.
Change oil w/Mobil 1 every 5,000 miles - use no oil.
Edit- Also had wiring harness repaired due to some %&@# rodent gnawing on the wires....
Old 13 Dec 2016, 01:07 pm
Originally Posted by CREWZIN View Post
Compare:
Ooh. Do those bushings last longer? good list! doesn't look like much has broke over 16 years for you!
Old 13 Dec 2016, 03:51 pm
Yes, they last longer but they make everything a little stiffer because there's less give than the rubber bushings.
Tags
extended warranty, repair list, repairs
Ok, my entry for Cruiser Of The Month July 2016 Carnut PT Cruiser Of The Month 6 10 Nov 2017 08:17 pm
I Need a Check List for my New 2010 Cruiser theptcrew General PT Cruiser Discussions 15 02 Aug 2016 03:08 pm
My entry for August 2016 Cruiser Of The Month Carnut PT Cruiser Of The Month 1 02 Aug 2016 08:27 am
List of problems with my PT and the cost of repair Dill General PT Cruiser Discussions 12 29 Jul 2015 09:50 pm
