2005 pt cruiser left headlight not working
Like Tree7Likes
  • 7 Post By 07ptclassic
Old 15 Dec 2016, 07:02 pm
Default 2005 pt cruiser left headlight not working
correction....the right headlight (passenger side) not working on low beam
I have a 2005 PT Cruiser Base model.
Passenger headlight no longer working on low beam. High beam is operational.
I replaced bulb and no change.
I check the fuses and replaced them both, still not working.
Anyone out there have any insight
Old 15 Dec 2016, 10:58 pm
Default Re: 2005 pt cruiser left headlight not working
I would suggest checking the wire harness and connectors going to the headlight.
Another member had a problem with one of the headlights in the link below.
Headlight wiring problem
Old 21 Dec 2016, 11:32 am
Turns out it was a ground wire not making proper contact.....Dad had a look at it for me. I had a new ground wire spliced in and attached to the proper ground location...all is good now.
'06 Right left front headlight dimmer than RH SilverGT06 General PT Cruiser Discussions 5 23 Oct 2016 05:26 pm
2005 PT Dream Cruiser - Brake and Tail Lights Stopped Working ArkansasTraveler General PT Cruiser Discussions 5 10 Aug 2015 07:42 pm
A/C not working - 2005 PT Cruiser coney107 Tech & Performance Forum 3 08 Jul 2015 05:49 pm
2005 PT Cruiser left side brake light not working bbodb1 General PT Cruiser Discussions 6 27 May 2014 07:13 pm
is there a headligh fuse for the left headlight on a pt 2001 themanatee Exterior Accessories Forum 4 07 Dec 2010 02:41 pm
