PT Cruiser startup headaches
Old 21 Dec 2016, 04:46 pm
Default PT Cruiser startup headaches
We had to change out a leaking heater core inside of a 2001 PT cruiser, and now we put things together and tried to start it up. It doesn't start up, it seems to try to and then it just stops. After a few attempts it doesn't even try anymore. Any idea what it could be? We are missing days at work and everything seems to be falling apart, fast.
Old 21 Dec 2016, 05:15 pm
rckstein's Avatar
Default Re: PT Cruiser startup headaches
Welcome to the forum
Old 21 Dec 2016, 06:10 pm
cruserdad1976's Avatar
well what did you disambeal?? there are a few plugs that are totally different but have thje exact same connections
Old 21 Dec 2016, 08:02 pm
Welcome to the forum.
Do you have a OBDII Scan tool to get the engine trouble codes? Post the codes if there are any.
Old 21 Dec 2016, 08:57 pm
Welcome
Old 21 Dec 2016, 10:40 pm
When I did my heater core a month ago, mine would not start. First issue was two plugs to the ignition and shift cable left unplugged Second issue was one of the large white connectors below the fuse panel by drivers left knee was not completely seated.
I would also check the large green connector behind the passenger side kick panel.
Good luck and welcome to the forum.
2003 GT
Old 22 Dec 2016, 05:53 pm
All I know, is that if I try to turn the car on, some sound comes out of the driver side door. Nothing else happens. The sound lasts for a few seconds, then nothing. Pretty much every wire going to the dash has been removed so we could remove the metal to pull the heater box in and put it back.
Old 22 Dec 2016, 06:04 pm
LOOSE CONECTIONS
Old 23 Dec 2016, 12:11 am
Any ideas where to start? It fired up today, after pulling the side view mirror controls, so I'm pretty sure your right about it being a loose connection somewhere. It fires up, but needs a little gas and then dies right away. Not like it's choking or anything, just dead. I was able to keep it running about the 5th time by flooring the gas. The gas peddle seemed to have no effect once it was running, and it idled making sounds as if I were tapping the gas. Latency to the gas peddle? I backed it about 10 feet and pulled it forward into a parking space, I let it run for about 15 minutes. I then shut it off, but now it doesn't click, or anything when I try to start it up. Any advice on whatever else it could be?
Old 23 Dec 2016, 12:59 am
_PTGT03's Avatar
my first guess is a battery load test should be done
Misfire at startup Hoser General PT Cruiser Discussions 19 16 Sep 2016 06:38 pm
Multifunction Switch, Fog Lamps and Headaches thecomputertechie General PT Cruiser Discussions 25 24 Aug 2016 08:22 am
2005 PT Turbo Cruiser smoking (a lot) on startup? bocacruiser PT Cruiser Convertible Forum 8 01 Apr 2013 06:49 pm
Redline at startup chap79 Tech & Performance Forum 13 12 Mar 2013 10:50 am
oil smell on startup spod General Turbo Discussions 1 28 Nov 2007 07:51 am
