Low Idle w/ 4th cyl Misfire
Like Tree2Likes
Old 23 Dec 2016, 08:01 am
Question Low Idle w/ 4th cyl Misfire
2005 2.4L - 124k Miles - No Mods or updates
For as long as I have owned the car it has had a rough idle, but recently it has gotten worse. the car is now idling around 100 Rpm per the Tack. it doesn't stall, just sits and shutters in park or stopped at a light. when RPMs are 500 or lower i get a 4th cylinder misfire, and it make the engine shake. it can be at cold or hot it will always start a misfire. Turning the A/C on makes the shudder worse and there is no increase in RPM. Engine Light is consistent on until the misfire then it flashes.
So far I have:
Changed Plugs - Gap .042
Changed Wires
Cleaned throttle body and sensors
Sea foam intake, oil, and fuel Clean
New IAC Valve
Checked vacuum leaks - None
Compression - Ok
Reset via battery disconnect
Old 23 Dec 2016, 09:25 am
Default Re: Low Idle w/ 4th cyl Misfire
Have you checked for broken motor mounts?
Old 23 Dec 2016, 01:29 pm
_PTGT03's Avatar
Change your computer or have the dealer re-flash a new firmware version for the PCM. There have been several technical service bulletins indicating problems with rough and low idle speeds on the 2.4L engine. A updated computer will have a factory authorized update sticker under the engine hood, mine has one.
Old 23 Dec 2016, 02:56 pm
rob302's Avatar
Originally Posted by Vpareker View Post
the car is now idling around 100 Rpm per the Tack. Engine Light is consistent on until the misfire then it flashes.
only time my car idled that low was when the coil burned out and it was only running on 2 cylinders, which was east to disgnose with the trouble codes. im not saying to go buy a coil.
if the engine light is on, what are the trouble codes?
Old 23 Dec 2016, 03:48 pm
So far I have:
Changed Wires
New IAC Valve
Compression - Ok
Is it 100 or 1,000 rpm?
Does both speeds on your radiator fan working properly? Try with the engine cold, start the engine, turn on the A/C and see if the radiator fan immediately comes on. If it does not I would suggest manually checking both speeds by applying 12 volts with the radiator fan plug unplugged. This will lower the rpm's at an idle.
Old 23 Dec 2016, 05:25 pm
I have been having similar issues. Idles about 700 - 750 rpm. Sounds like a diesel. No misfire codes at all. Runs good otherwise except shifting at high rpm such as goosing it getting on the freeway, seems to lag shifting into next gear or overdrive unless letting off the throttle. 150 k and its just getting old I guess. Time for a new car. I am beginning to think its the PCM as well. some have said to get diagnostic reader and leave it plugged in to monitor things. So you did a compression check? I need to get a vacuum gage. My old one is ng. That can tell you a lot too. I pulled the big booster line off and the engine revved up so I do not see how a vacuum leak would drop idle speed. Another problem I have read on here is the gasket at the block where the intake plenum attaches is a problem that cause similar symptoms. Be nice if it threw a code at least saying sensor "?" is malfunctioned. I am thinking of changing the 02 sensors since they have never been done. Good luck finding your problem
Old 23 Dec 2016, 07:58 pm
_PTGT03's Avatar
The target idle speed on these cars is between 700 to 750 rpm. there is no problem with the idle speed on yours. It's something else. Try pouring two quart of acetone or xylene into the gas and let it idle for 30 minutes to see if the symptoms go away.
Old 23 Dec 2016, 08:57 pm
No instructions as how fast these chemicals have to be through the system before it damages fuel related components? This is a very dangerous suggestion and should not be attempted.
Old 23 Dec 2016, 09:28 pm
_PTGT03's Avatar
respectfully, you have no idea what you're talking about.
Old 23 Dec 2016, 11:48 pm
Using acetone is a bad idea.
Acetone is known to deteriorate cheap plastics and other substances. While the components in a car's fuel system should be of high quality, and thus immune to any deleterious effects from exposure to acetone, be aware that "ideal" is not always the case in practice. Be advised that not all systems have been tested against acetone. Until such thorough testing has been accomplished and certified by an accredited authority, you assume your own liability for experimentally testing acetone in your particular system.
As I said before I would suggest not giving out this advice anymore. It sounds like you want someone else to check out your theory and if it damages the fuel system components you will know not to try it on your own PT Cruiser.
Since you say you are an expert on this issue prove to me that testing has been accomplished and certified by an accredited authority for the PT Cruisers.
Seems to me you are violating forum rules getting other members to try out your experiments for you.
chuzz likes this.
Tags
cylinder nonfire, engine help, low idle, misfire, rough idle
'01 PT Limited seems to misfire at idle brickdaddy77 Tech & Performance Forum 6 28 Jun 2015 12:56 am
Misfire at Idle and P0302 code TurboJohn Turbo Performance 18 02 Jan 2014 09:34 pm
misfire at idle. 2003 PT Cruiser Berthold Tech & Performance Forum 6 18 Dec 2012 01:15 pm
need advise on ruff idle and cylinder misfire nomadman1956 Tech & Performance Forum 4 22 Jul 2012 11:30 pm
misfire code at idle specialkay Tech & Performance Forum 4 08 Dec 2011 08:28 pm
