P0016
  • 1 Post By ptcruisersteve
Old 28 Dec 2016, 08:02 am
hfd hfd is offline
Default P0016
2007 PT 2.4L .TIMING BELT SLIPPED. REPLACED RUNS FINE BUT KEEP GETTING P0016 CODE.ANY SUGGESTIONS.TKS IN ADVANCE
Old 28 Dec 2016, 08:29 am
rckstein's Avatar
Default Re: P0016
Welcome to the forum
Old 28 Dec 2016, 11:15 am
Default Re: P0016
Welcome to the forum.
P0016 - Crankshaft/Camshaft Timing Misalignment :
Possible Causes:
Camshaft timing is not correct
Crankshaft or Camshaft Sensor signal is erratic
Crankshaft or Camshaft Sensor, harness or connector has failed
PCM has failed
I would suggest using a vacuum gauge for reading, if the belt is off a tooth it will reflect in either a very high idle HG or very low.
An engine that is in good condition will idle between 16-18 steady on most 2.4 engines.
Was the head removed replacing the timing belt?
Was the alignment of the camshaft gears the same as the image below on TDC?
Old 28 Dec 2016, 06:00 pm
hfd hfd is offline
Default Re: P0016
not sure was done before i bought car.
Old 28 Dec 2016, 11:19 pm
_PTGT03's Avatar
Default Re: P0016
THEN YOU SHOULD MAKE SURE IT WAS DONE
Old 29 Dec 2016, 12:12 am
Default Re: P0016
When the letters are capitalized it means you are shouting. There is no need to shout.
rob302 likes this.
code p0016 ptbruiser2003 Tech & Performance Forum 23 23 Oct 2013 01:44 am
No Cruise and P0016 altaylor Tech & Performance Forum 5 15 May 2013 05:46 am
P0016 sleepy General Turbo Discussions 0 01 Mar 2013 03:30 pm
p0016 code guss Welcome New PT Cruiser Members 2 18 Feb 2012 05:09 pm
P0016 Keep on trucking??? Shotgun33 Tech & Performance Forum 3 18 Jul 2011 04:35 pm
