ABS, Brake and Traction light on
Old 30 Dec 2016, 12:09 pm
Default ABS, Brake and Traction light on
The lights have been on the last 9 months and no problem driving the car. Yesterday took the 03 GT in and had the shop replace radiator that was under warranty and they ran a test on the ABS and the code came up, Code 22 CAB Failure and was told that I need a ABS Module. The damn thing cost over 600.00 dollars to replace. Can I replace it with another one from another PT ? Also will it pass smog here in Cal with the ABS, Brake and Trac light on ?
Old 30 Dec 2016, 12:46 pm
Default Re: ABS, Brake and Traction light on
I'm pretty sure you won't pass inspection with lights on. Check with Lynn. He will know for fact if so. Yes you can replace from a used PT. You will need to find out the proper way to bleed the air. Again Lynn will be your best option for help on this.
Old 30 Dec 2016, 01:22 pm
Thanks Sir
Old 30 Dec 2016, 03:41 pm
Always welcome my friend.
Old 14 Jan 2017, 03:47 am
Sinbad's Avatar
Started mine up to come home from the pub last night and got all 3 lights on
Drove OK, so I pootled home through the snow. Turned it off when I got home, locked it and unlocked it, started up again - this time just the ABS and the Trac Off lights on
Havent started it yet this morning, so I don't know what I will get, but is this a common electrical gremlin, and is there anything "known" to look out for?
(PS: At first I thought it was my lock blipper going AWOL as it wouldn't lock or unlock in the pub car park when I got there - I had to unlock it with the key to get home - but by the time I got home it was working OK.)
Old 14 Jan 2017, 04:25 am
_PTGT03's Avatar
Audi ABS modules new cost over $1200 on year 2000 models (and that was list price back in that year too). I wouldn't be complaining about a high cost as it's a great value compared to other cars.
Old 14 Jan 2017, 06:45 am
Sinbad's Avatar
Lights were on, then went out after 50 metres driving... I'm obviously going to have to go through the electrics and clean contacts come the spring weather
Old 14 Jan 2017, 08:37 am
your problem is in the ABS system. Could be a faulty wheel sensor or anything else in the system. Need to have your computer red to find out what codes are stored in there. A sparatic problem will allow the code to reset the light.
Sinbad likes this.
Old 14 Jan 2017, 10:49 pm
Sinbad's Avatar
Thanks... I shall start saving
Old 28 Sep 2017, 09:07 pm
so if there are codes they won't come up on the key flipping? I currently have abs/trac issue with no codes that i can get from the key.
2003 PT Cruiser GT Turbo 78k miles
Purchased this summer for my daughter, front end wrecked, but just radiator, ac condenser,
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
abs traction control light stevej3383 General PT Cruiser Discussions 8 05 Jul 2014 07:08 am
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Traction control, ABS, and Brake lights stay on RHCruiser Tech & Performance Forum 4 11 Sep 2013 05:35 pm
Traction/ABS light turbomangt Tech & Performance Forum 4 05 Jan 2011 06:01 pm
