Hi. 2003 base. lately if you step on brake or if cooling fans kick on, headlights will dim (flicker) for just an instant. Had battery checked, ok, had alternator checked, ok. which doesn't mean could not be problem. all else seems normal.
Was a battery load test done with the battery in the PT Cruiser? Was the battery load tester adjusted to the load the battery is suppose to hold? Sometimes they just make it 400 amps for a 4 cylinder engine.
If at First You Don't Succeed - Try, Try Again |
thanks, no engine lights on, also noted my fog lights have quit and in the last 2 months had to be jumped twice. the only test to battery was done at advance auto, other than those 2, starts fine.
Since you've revealed a little more information (fog lights), perhaps you have a short in your multi-function switch (MFS). It's not an uncommon problem with the PT's that have fog lights.
![]() Aspire to inspire before you expire. |
![]() Quote:
The link below might help you check to see if you have a battery drain. How to Find a Parasitic Battery Drain: 9 Steps (with Pictures) The amps should be no more than around .01-.05 amps max. with the ignition off.
If at First You Don't Succeed - Try, Try Again Last edited by ptcruisersteve; 31 Dec 2016 at 06:26 pm. |
Thread Tools | |
Display Modes | |
Head light and clock flicker | TexasPTCruisin | General PT Cruiser Discussions | 7 | 17 Feb 2013 08:32 pm |
Wipers coming on and Lights flicker Help | srbptc | General PT Cruiser Discussions | 2 | 16 Oct 2011 08:41 am |
Tried searching: Lights flicker at idle | PDubs | General Turbo Discussions | 2 | 12 Jan 2010 12:07 am |
Cure for dimming/flicker lights | igormina | General Turbo Discussions | 44 | 22 Nov 2009 07:39 pm |
Lights Flicker | obwan | General PT Cruiser Discussions | 10 | 15 Feb 2004 04:00 pm |
