09 Jan 2017, 11:37 am
Re: Overheated! Diagnosis/Plan Needed
Originally Posted by tpcroozer
OK, bought a sweet 2006 GT convertible with just 85K on it. Drove it a few weeks and life was good... My son in law got a new job that was about 30 miles away and needed something that got decent mileage so he started driving the PT. On the night of the 3rd day, the car overheated to the point that it shut down. He said he had no warning lights until the overheat. He coasted to a point and called me. I drove over and picked him up so we could let it cool off. When we returned, we added a gallon of 50/50 universal antifreeze. We could see there was a drip on the drivers side that was pretty bad but we were only about 3 miles from home. We started it up. It took about 10-15 seconds of cranking before it started but didn't smoke and the engine idled fine and seemed to have full power.
We coasted into the drive way and let it cool off until the next day to try and diagnose the leak location in daylight. The best I can tell it is the radiator, so I ordered one online. It has now arrived and I'm ready to remove the old one and install the new but am hoping for some long distance but experienced input on a few things...
1st question: The car is taking about 6-10 seconds of cranking before it will start. I don't see any water in the oil or smoke from the tailpipe. The oil definitely has a burned smell and needs to be changed. What kind of things will cause the delayed start and what should be my game plan for diagnosis?
2nd question: When replacing the radiator, should I replace both hoses and the thermostat at the same time or should I stick with one thing at a time?
Many Thanks!
-Troy
Let discuss a plan forward. This would be mine.
The slow start (engine turns over fine but must spin a while to start) is likely from a loss of compression on one or more cylinders due to a failed head gasket. But it might just be spoiled spark plugs. Based on the reports here and the many many salvage PT's I've picked over, blow head gaskets are extremely common on these cars and can be expected after any major overheating event.
I will first pull the plugs and examine them for signs of coolant damage. I'd look into the cylinders to see is there is coolant in them. I would perform a compression test. If any of these gave an indication, I would then replace the head gasket first before buying a new radiator, hose, etc.
While the head is off, I'd take it to a machine shop for rebuild. This is money VERY WELL spent as it assures your head is good and renews it for many more miles of good service.
I'd reinstall the head with new gasket along with a new timing belt, water pump, tensioner and idler pulley. New plugs too. I'd fill the cooling system with water and see how well the engine runs. If it runs well, I'd then flush the cooling system thoroughly. Then I'd buy and install a new radiator, thermostat, hoses and the rest.
