Hi,
The battery and alternator were changed. I get a battery drain when i checked whit an ampmeter I found that if I take off the IOD fuse out the drain drops to 0.02 so almost disappear. Any ideas? Is it ok to keep that fuse out? Thanks |
![]() Quote:
![]() PT problems read this FIRST |
Thank you.
2003 with 50k on it. Second owner. No Mods. Just got the PT for the wife ...but this problem gets her mad..lol The car won't start if not use for a day Last edited by Zoile; 23 Jan 2017 at 11:27 am. |
The PT Cruiser should be drawing 5 to 35 milliamps of current after a few minutes of being shut down with the key out of the ignition.
A quick no-cost test is to make sure there is no CD in the player. Sometimes the CD player tries to read a non-existent CD so you can also test the current draw after sticking in a CD then ejecting it and turning the radio off. You could also methodically test each of these one at a time to see if the current draw goes down: Door locks (front ones and back ones) Window switches Features on the multi function switch (switches on the turn indicator lever) Of course you can also put the ammeter across the IOD fuse socket and remove one fuse at a time to see which circuit is causing the excessive drain and narrow it down that way tool. Last edited by rsrocket1; 23 Jan 2017 at 02:02 pm. |
Thanks for the info.
I tested the alternator and it charges ok.( it as been changed) The battery is new. When i stop the car the battery is at 12.4 so it's charged. I don't know but it's getting frustrating, the battery gets drained. Quote:
One correction..
The PT Cruiser voltage should be min *13.50 volts engine idle speed. This is the *default to the charging system should any sensor fail and the generator is still in good health. Your response #8 information about the battery needs to be addressed more. You voltage is making me suspect if anything that you should have the battery properly load tested. Nitro's way of checking a battery
To view larger pictures simply "click " on the picture! Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() ![]() Last edited by NitroPT; 23 Jan 2017 at 02:21 pm. |
![]() Quote:
![]() Or a Digital Volt/ohm meter ![]() |
Thread Tools | |
Display Modes | |
Do PT's drain the battery if not used often? | NZbling | General PT Cruiser Discussions | 13 | 28 Jul 2015 11:44 am |
battery drain on a 2006 | reclasses | General PT Cruiser Discussions | 2 | 13 Feb 2015 11:18 pm |
Battery drain question | yourlefthand | Tech & Performance Forum | 13 | 16 Jul 2014 12:21 pm |
Battery Drain | bmeador55 | Stage Turbo Kits | 2 | 10 Jul 2013 09:04 pm |
Battery Drain ??? | Derrick | Tech & Performance Forum | 18 | 28 Feb 2010 07:44 pm |
