Recurring radiator fan failures
  • 1 Post By Gsnewsome
Old 28 Jan 2017, 10:29 am
Default Recurring radiator fan failures
Fighting a recurring issue with my wife's 2005 cruiser. I've replaced the radiator fan assembly three times. Frequency of failure is increasing. First fan lasted almost a year with the most recent only lasting a few weeks. Either poor fan reliability or something else causing the failures. May try an Oem fan next over another am one from Autozone. Wife is getting good at managing engine temps with the heater when the fan fails...
Old 28 Jan 2017, 10:56 am
Default Re: Recurring radiator fan failures
Are you paying for the new fans? Next time if you pick up a "DORMAN" fan at one of the better known auto stores or Rock Auto, they have a lifetime replacement warranty. That doesn't solve your problem of why they are going bad but at least you won't have to pay for a replacement.
Old 28 Jan 2017, 11:17 am
What brand radiator fans are you putting in the PT Cruiser?
Old 28 Jan 2017, 11:29 am
rckstein's Avatar
Welcome to the forum
Are you getting the bare fan, or fan complete with new relays and wiring harness?
Old 28 Jan 2017, 11:48 am
The fans are dorman pn 620-022 from Autozone. Lifetime warranty, so I'm not paying for the replacements.
CREWZIN likes this.
Old 28 Jan 2017, 01:26 pm
LionPT's Avatar
Are you sure the fan went out & it's not just a blown relay..??
Old 30 Jan 2017, 12:11 am
rsrocket1's Avatar
Check the wiring especially your connectors. An intermittent connection will cause arcing between the brushes and commutator which will wear out a brush in no time. There's no way a brushed fans should fail within a couple of weeks. Unfortunately many of the new Doorman fan assemblies don't have plug in relays. The relays are wired in and you can't get to the contacts. If you could get to the contacts, you could easily tell if the brushed have lost contact using a digital multimeter.
Recurring dead battery SteamboatWillie General PT Cruiser Discussions 8 03 Jun 2014 09:25 am
Recurring P0344, Camshaft Position Sensor reading 04PTneedshelp Tech & Performance Forum 8 27 Feb 2014 11:51 pm
catostrophic tranmission failures awsumpt General PT Cruiser Discussions 34 24 Dec 2011 08:31 pm
Multiple Sensor Failures 2006 SusanMD General PT Cruiser Discussions 1 02 Dec 2010 03:31 pm
Oh the failures Dirk_Gently General PT Cruiser Discussions 9 01 Oct 2008 04:27 pm
