2003 PT radiator issue
Like Tree4Likes
  #11 (permalink)
Old 17 Feb 2017, 12:25 pm
Default Re: 2003 PT radiator issue
Here is the picture that the user posted in her album section......
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
  #12 (permalink)
Old 17 Feb 2017, 03:07 pm
LionPT's Avatar
Can't tell anything with that pic.
Nexus 5X, Nexus 4, Nexus 7 (2013)
  #13 (permalink)
Old 17 Feb 2017, 03:41 pm
Icandoyourtaxes's Avatar
I just received a call from a shop and they say it is the water pump that went out. How much should that cost to fix? They quoted me $830. I only paid $700 for the entire car. I am completely stranded without it. Just want advice on wether or not Inam being lied to for more money.
  #14 (permalink)
Old 17 Feb 2017, 04:20 pm
I would get a second opinion.
You have a history of what has been done to the PT Cruiser?
LionPT likes this.
  #15 (permalink)
Old 17 Feb 2017, 07:16 pm
Wink Re: 2003 PT radiator issue
Any help would be wonderful. I'm a very smart girl, but know little about cars. My 2003 PT is leaking out of the bottom of the passanger side of the radiator. It is coming out of what looks like some kind of circle shaped plug or seal of some kind. It looks like part of the radiator but I am not sure. I am uploading a photo in my album on my profile unless i can attach it this post.
Thank you for your imput. I really need this car to run.
Welcome to the forum and sorry to hear about your coolant issue. I have carefully read your posts and post #7 and #9 seem to not justify a water pump failure due to the massive leak you describe. Water pumps do fail and leak, usually much slower than your description of your car's leak. Without a close personal inspection of your car, based on your events leading up to the leak, it does sound like you damaged the radiator when you hit that object you mentioned. The tanks on these radiators are plastic and can easily be broken. In addition, if you indeed do have a water pump failure it is a labor intensive job and the cost is in the labor charge, the pump itself is not that expensive. Perhaps you live close to a member that can look at your car and help you diagnose the leak, as Lion Pt stated the picture is inconclusive for isolating the problem. As I said though, your leak is most likely the radiator and that would be a much more pocketbook friendly repair.
CREWZIN likes this.
  #16 (permalink)
Old 25 Feb 2017, 09:33 am
LionPT's Avatar
Any news on your PT, what did you decide to do..??
radiator fan issue tomkelley80926 Tech & Performance Forum 15 07 Sep 2015 01:23 pm
Radiator fan issue henryk General PT Cruiser Discussions 5 18 Jun 2015 02:46 pm
Help! Radiator fan Issue parkerjohn Tech & Performance Forum 1 22 Jan 2014 06:47 am
HELP!!! Possible radiator issue faguin General PT Cruiser Discussions 8 09 Apr 2013 06:40 pm
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
