I purchased my Cruiser the beginning of December and I'm finally about done replacing parts. As with any vehicle I buy I always go over them and service whatever needs to be done and sometime a bit more. I'm the 3rd owner and from what I can tell other than oil changes the last owner did very little maintenance. At least they had the heater core changed before I bought it.
So far I've done the following: Timing belt (complete kit) Both Torque struts and engine mount Front and rear Struts/shocks Both front wheel bearings Both front control arms and tie rod ends Spark plugs and wires Drive belts with tensioner and idler Alternator 4 new tires 4 wheel alignment Windshield (had a crack along the bottom) Next on the list: Brakes and rotors front and rear. Radiator hoses Trans filter/fluid change. Heater control cable retaining clips and adjustment When I got the car it didn't have heat I found whoever changed the heater core broke/lost the retainers for the control cables and used wire ties to hold the cables in place. The adjustment is all wrong as well. I did a quick repair to get at least the defrosters and dash vents blowing heat. I ordered the retainers and will have them this week. Hopefully the adjustment issues will be at the controls. Barring any major engine or transmission failures I should be in good shape now.
2002 Limited Edition 2.4 Auto with 177k Miles ![]() |
Don't jinx yourself. I pretty much replaced all the same parts you did during this last couple months and thought I would be good to go. After driving it daily for a week, ding. Check engine light. Hhhmm, what could it be.
P0441 Evaporative System Malfunction Incorrect Purge Flow P0420 Catalyst System Efficiency Below Threshold ![]() They could be related. Troubleshooting in progress. Hope you have better luck. |
Whoa! I'm going to use your list as reference for my PT project.
Just had the following replaced: Calipers, Rotors, Brake Pads and Hoses Valve Cover Gasket Plenum Gaskets Spark Plugs and Wires This week hopefully i'll get the following replaced this week. Wheel bearing and hub assembly Problem Solver Front end kit (lower control arms, tie rod and stabilizer bar) Motor mounts (3) Oil pressure switch\sender (oil light goes on when car is first started) Thanks for you post.
MyFuzzyDice ![]() 2005 Base Black PT with Fuzzy Dices (Original Owner) New Brake System, Wheel and Hub Assembly and Problem Solver front end kit. ![]() |
Thread Tools | |
Display Modes | |
Does replacing parts ever stop with these cars? | Snettles | Northwest PT Forum | 43 | 10 Apr 2016 04:43 pm |
2004 pt cruiser convertible parts need repair or replacing | gman69 | PT Cruiser Convertible Forum | 0 | 19 Nov 2015 07:28 am |
rough idol after replacing parts | rot814 | Tech & Performance Forum | 3 | 01 Dec 2012 09:01 pm |
Replacing bumper- any other parts I'll need? (pics) | Vaskania | Exterior Accessories Forum | 17 | 21 Nov 2010 06:06 pm |
