2006 Cruiser turn signals and brake lights not working
Old 26 Feb 2017, 12:01 am
Default 2006 Cruiser turn signals and brake lights not working
Hello all,
Recently our brake lights and turn signals stopped working. The turn signals dont work at all, front or rear, though the light blinks on the dash.
Two of the three brake lights (center and right) will work if the headlights are off, but with the headlights on they don't work at all.
Some googling suggests this maybe an issue with a fuse, or could there be a more serious electrical problem?
Any suggestions or advice is appreciated!
Old 26 Feb 2017, 12:20 am
rckstein's Avatar
Default Re: 2006 Cruiser turn signals and brake lights not working
Welcome to the forum
Old 26 Feb 2017, 12:51 am
Welcome to the forum.
Does your hazard lights work?
Does your wipers work?
Did both turn signals and brake lights stop working at the same time?
Old 26 Feb 2017, 01:28 am
Thank you for the welcome
the hazard lights do not work
the wipers work, front and back, with the headlights on or off.
I'm unsure if they stopped working at the same time. I noticed that they weren't working at the same time, but thinking back at how some people have been reacting when I merge.. maybe they've been out for a while..
Old 26 Feb 2017, 02:33 am
EDIT: I went back and re-read your 1st post more closely. At 1st I thought fuse, but then read you have brake lights if the headlights are off. This now makes me think bad ground back there. Locate and clean the grounds and the problem will probably go away.
EDIT TO EDIT: Apparently there is a TIPM involved. I start getting nervous when there's a module involved. Well if it were mine, I'd still start by cleaning all the grounds I could find back there and checking all the bulbs. Beyond that I'm not going to be of much help.
Old 26 Feb 2017, 10:09 pm
Does your power door locks and key remote work?
Old 28 Feb 2017, 11:57 am
Yes they do. I'm going to poke around in the fuse box and see if any of them look burnt out.
thanks all for your suggestions so far!
Old 28 Feb 2017, 01:49 pm
LionPT's Avatar
Fuse #3 controls the 3rd brake light.
There are no other fuses or relays for the blinkers or the brakes in the G2's. 2006-2010.
Old 28 Feb 2017, 04:31 pm
I would suggest checking the G302 & G303 ground connections that the tail lights,turn signals, and hazards depend on. Make sure you are making good contacts. If that is good I would check the battery voltage after you turn on your headlights. If the battery voltage goes down I would suggest checking to see if your headlights are drawing excessive current.
Old 04 Mar 2017, 04:17 pm
can you offer any advice on how to find these? im not sure what im looking for and havent been able to find any pictures by googling or looking in the manual.
also i checked every fuse in the box and none was burnt out. I took the rear lights out and the bulbs were fine and the wiring looked fine to me but im not really sure what to look for. no obvious frayed or old looking wires though. not sure how to go about taking out the front lights.
also another thing i noticed is that all brake lights come on when the e-brake is on (even when the headlights are on). (as opposed to only the middle and right when the headlights are off, and none when the headlights are on)
thanks again for any tips or advice
Tags
2006, brake lights, brakes, fuse, turn signals
Turn Signals Lighting Up with Brake Lights PentastarThunder General PT Cruiser Discussions 8 03 Feb 2016 09:58 am
Turn signals,wipers,brights not working 2006 Pinball General PT Cruiser Discussions 11 31 Oct 2015 07:20 pm
2006 Cruiser Turn signals and Hazards libilou Tech & Performance Forum 28 17 Sep 2014 05:21 am
05 Touring turn signals working & not working angel66rose Tech & Performance Forum 5 11 Dec 2013 09:34 am
Turn Signals Not Working Indynick General PT Cruiser Discussions 9 15 Sep 2004 02:25 pm
