I have a 2007 PT and there are a few things going wrong. First when it gets really cold the car wont start, it tries to turn over but just wont catch. I put that gas line antifreeze in every time I fill up on gas. I also have taken my battery to get checked and its good. So its not my battery. And getting a jump dont work.
Second, a lot recently after driving it when I turn it off it has a bubbling or gurgling sound and steam comes out from under the hood. I have checked the fluids and all is full. Its also not registering that it is over heating but the gauge is working. Can someone please give me some advice as to what the problem is. |
I am suggesting you might have two problems.
The first suggested problem is your battery may not be performing properly. When the weather is cold charge the battery for an hour with a battery charger and see if it starts. If it does there is a good chance your battery is bad. The second suggestion is making sure you don't have air in the coolant system. I would do a engine coolant pressure test to see if the coolant is leaking somewhere else allowing air in the coolant system. Sometimes the hose from the radiator cap to the overflow tank goes bad and allows air to into the coolant system. Also check the radiator cap. After you drive your PT Cruiser and you let the engine cool off take the radiator cap off and see if your coolant is filled to the top.
If at First You Don't Succeed - Try, Try Again Last edited by ptcruisersteve; 26 Feb 2017 at 04:34 pm. |
I recently had to replace my 06 radiator after seeing steam coming from under the hood.. Not a bad leak as it was the top crimped seam of the radiator, so There was no dripping antiFreeze..
Your hard starting, if its not the low charge on the battery you may need a new set of spark plugs.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
As far as not starting if you can come up with a scanner check the eng temp with the outside temp. If you sender is bad and reading 70 when it's 20 the car won't start .
As far as the overheat better get that checked right away. Can be anything but if you do nothing a simple problem will quickly turn into a major one. Good luck Mike |
![]() Quote:
As to the coolant problem, I'd also check for a leak by the bottom of the thermostat housing. When that gasket goes bad, it will also allow air into the system as the engine cools down. Might be a good idea to pop the hood when it is steaming to see if a leak point can be spotted, would help to know what area the steam is escaping from. |
Thread Tools | |
Display Modes | |
