Oil Leaking from Center Of Flexplate?
Like Tree2Likes
  • 1 Post By rob302
  • 1 Post By GtPt05
Old 07 Mar 2017, 06:38 pm
Flash619's Avatar
Default Oil Leaking from Center Of Flexplate?
Okay so recently if you've seen any of my other threads you know I'm pulling my broken transmission to replace. I got the transmission out after a bit of work and I looked at the flexplate.
Now look at the below image, is it just me or is oil coming from the middle of the flexplate? Am I loosing my mind? Would this be a bearing?
Old 07 Mar 2017, 10:06 pm
Flash619's Avatar
Default Re: Oil Leaking from Center Of Flexplate?
I've fixed the image link as it had seemed to be broken.
Old 07 Mar 2017, 10:37 pm
LionPT's Avatar
Old 07 Mar 2017, 11:08 pm
Handy_Cruiser's Avatar
Okay,
This is 2003 PT Limited with auto transmission, right?
Here's some photos of what the crank seal and end of the crank look like. These photos are from a turbo, but yours should be very similar.
There doesn't appear to be any way for oil to leak from the pilot hole in the rear of the crankshaft. If me, and if this worried me, I'd likely remove the flex plate for a better look. I'd go ahead and replace the rear crank seal too if shows signs of leaking. Might do it anyway since I was already there.
It should be noted that I am a Safety Engineer among other things and I haven't worked as a professional mechanic since I was young strapping lad with long sexy flowing hair before college. And even then, I mainly worked on big trucks and heavy equipment. Nowadays, I enjoy working on these funny looking little cars for fun and relaxation.
Old 08 Mar 2017, 01:23 am
rob302's Avatar
Take it apart. At that point you should be changing the rear main seal anyhow.
I greased that on mine for ease of reassembly. Maybe
Someone used oil on yours
Handy_Cruiser likes this.
Old 08 Mar 2017, 12:27 pm
I must be doing it wrong...
Carnut likes this.
How to Inspect Flexplate for Loose Bolts bennyc General PT Cruiser Discussions 15 25 Sep 2017 04:31 pm
What is leaking??? ddres0605 General PT Cruiser Discussions 5 14 Mar 2016 09:47 am
05 Limited Turbo Flexplate rattle? plantmeisterjohn Tech & Performance Forum 4 09 Jul 2012 01:01 pm
Oil Leaking kairobsor Tech & Performance Forum 4 30 Aug 2009 01:10 am
oil leaking ptma767 General PT Cruiser Discussions 11 20 Feb 2008 07:42 pm
