Serpentine Belt 200LX 2.4
  • 1 Post By GotToGo
Old 12 Mar 2017, 09:42 pm
Default Serpentine Belt 200LX 2.4
Hi All,
I'm having trouble replacing the belt on a 200LX, I thought maybe someone here could help.
Does anyone have access to a manual or experience with the 200LX 2.4? Or know of a specific writeup for the serpentine belt?
The belt won't go back on and the tensioner doesn't look like any pictures I've found. I'm moving it as much as I can (which is maybe 1/2 inch) but I still need about 1/2 inch more.
I'm sure the belt routing is correct, it can really go on only one way.
I'm really scratchin' my head on this one so any help would be appreciated.
Old 12 Mar 2017, 10:58 pm
rob302's Avatar
Default Re: Serpentine Belt 200LX 2.4
This is all it says..
figure 1 - ACCESSORY DRIVE BELT - WORLD ENGINE WITH A/C
NOTE:
When installing drive belt on the pulleys, make sure that belt is properly routed and all V-grooves make proper contact with pulley grooves.
Install the accessory drive belt (3) around all the pulleys except for the idler pulley (2).
Using a wrench, rotate accessory drive belt tensioner (1) counterclockwise until accessory drive belt (3) can be installed on the idler pulley (2). Release spring tension onto accessory drive belt (3)
Old 12 Mar 2017, 11:52 pm
Thanks Rob.
Guess I'll just keep beating on it.
Old 13 Mar 2017, 06:23 am
Are you sure you're trying to move the actual belt tensioner and not just a stationary idler? I've seen it happen. If the tensioner isn't moving, then you probably need to replace it. It could be frozen.
Old 13 Mar 2017, 09:20 am
Naw, its the tensioner. It does move, just not enough. It may be bad though. I'll. See when I get back to it later.
Old 13 Mar 2017, 10:53 am
I got it. Just needed a bigger stick.
That's one strong spring, or I'm just old.
rob302 likes this.
Old 13 Mar 2017, 11:42 am
It's amazing how much tension some of those bad boys hold. A longer extension on a wrench always comes in handy. I have 3 different length cheater bars that I use from time to time. And NONE of them are PVC. All metal.
Serpentine belt change yteka99 Tech & Performance Forum 18 11 May 2017 02:41 pm
serpentine belt problem jdv Tech & Performance Forum 7 27 Dec 2014 05:25 pm
02' Serpentine belt change Help! dzyubin Tech & Performance Forum 15 13 May 2012 10:41 pm
Serpentine Belt Misalignment dcsocal Tech & Performance Forum 8 07 Apr 2012 01:34 pm
New serpentine belt already? RJ General PT Cruiser Discussions 4 07 Sep 2004 08:12 am
