New Guy - 1st problem - power steering
Like Tree3Likes
Old 13 Mar 2017, 09:50 am
Default New Guy - 1st problem - power steering
Been hanging around for a while before I bought a used PT, thought I'd picked the best inexpensive one with not too much work needed. It came from po with no serpentine belt (and also no splash guard) replaced the belt but the power steering pulley seems out of line, can it be moved? The belt always seems to go back to being half way off and the ps only works on high revs. Thanks in advance for any help.
Old 13 Mar 2017, 09:56 am
rob302's Avatar
Default Re: New Guy - 1st problem - power steering
every time we've seen this here, it's because the crank pulley isn't on far enough
...assuming the tensioner, idler, PS and AC all seem to spin freely and are on properly of course
BluePT03 likes this.
Old 13 Mar 2017, 09:59 am
rob302's Avatar
01 power steering pulley alignment
Old 13 Mar 2017, 11:09 am
Handy_Cruiser's Avatar
On some of the early PT's, the power steering pump didn't line up right. So at the factory, they left the press-fit power steering pulley out about a half inch or so on the shaft. As long as the belt is running straight, leave it that way. If the pulley is flush with the shaft and the belt is too far back, take a pulley removal tool and pull it out until aligned. It shouldn't need to come out no more than a half inch.
Also, you can see all this very clearly and more easily get to it if you remove the right headlight assembly.
rockandroller likes this.
Old 13 Mar 2017, 11:25 am
rckstein's Avatar
Welcome to the forum
Old 13 Mar 2017, 12:35 pm
Thanks for the fast replies, so I should be able to remove the headlight and align the pulley? Also the splash guard, doesn't seem like a great idea to run it without one, I guess I'll have to see if the local salvage yard has one.
Old 13 Mar 2017, 01:37 pm
The bolts that hold the splash guard to the chassis can be really difficult to remove. And the splash guard is easy to just rip off by hand. So from what I've seen, many PT's that have had work done on the right side of the engine will be missing this cover. It can actually hard to find a good one at the salvage yard.
Old 13 Mar 2017, 04:09 pm
VsandFords's Avatar
Welcome to the forum from Texas.
Old 21 Mar 2017, 10:37 am
I added an image, hope this works. Hopefully you can see how iris just the power steering pulley that is out of line, can I push it on further without taking the pump out of the car?
Old 21 Mar 2017, 10:40 am
rob302's Avatar
i would remove the belt and see if that pump even spins freely. i can't imagine that happening unless the pump was locked and the pulley was slipping on the shaft.
i would assume that needs to be removed from the car, and more than likely will need to be replaced
Power steering problem, please help. nickd Tech & Performance Forum 3 02 Sep 2011 05:09 am
Power Steering Problem mdfrodolives Tech & Performance Forum 2 24 Dec 2010 10:16 pm
Power steering problem..pls help: myfirstptc General PT Cruiser Discussions 10 09 Nov 2010 07:18 pm
Yet another Power Steering problem fritz_t_coyote Tech & Performance Forum 3 23 Nov 2005 04:28 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
