Where did the power go?
Like Tree10Likes
  • 1 Post By rob302
  • 1 Post By rob302
  • 3 Post By rob302
  • 4 Post By VsandFords
  • 1 Post By rob302
Old 16 Mar 2017, 01:44 pm
VsandFords's Avatar
Default Where did the power go?
Until yesterday, I was powering my 2 gauge pod using the #3 pin in the heated seat relay port on my fuse panel. My 01 LE doesn't have seated seats so, this is an open port.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
This pin is hot with the ignition, well it was until yesterday. When I pull the connector and tap into pin 4, in diagram/pin 5, in picture, which is hot all the time, the gauges work.
This is also the trigger point for the relay to my fog/driving lights after I bypassed my MFS.
Can someone help find my lost my power?
Old 16 Mar 2017, 02:12 pm
rob302's Avatar
Default Re: Where did the power go?
you might review this until a better answer comes along..
Heated Seat Relay Wiring -- I'll even pay a bounty on this one
VsandFords likes this.
Old 16 Mar 2017, 02:18 pm
rob302's Avatar
i think before i looked anything up or investigated, i would start by wiggling the steering wheel up and down, and then checking the under hood fuses, as well as the grey connector behind the inside fusebox
with the key on of course
Old 16 Mar 2017, 02:41 pm
VsandFords's Avatar
After reading that, I know it's a white wire. I still don't know where the power is.
Old 16 Mar 2017, 03:24 pm
rob302's Avatar
check fuse #6 inside and check the socket for power. it's the only white wire listed as "fused ignition switch output (run)"
fuses sockets 5, 6, and 7 are all powered together so if 6 is dead, see it 5 and 7 are as well... if so, check fuse 4 underhood.
Old 16 Mar 2017, 03:31 pm
rob302's Avatar
diagram to go along with it..
good luck!
Old 16 Mar 2017, 03:34 pm
rob302's Avatar
might want this one too... doubt it though.
Old 16 Mar 2017, 06:26 pm
VsandFords's Avatar
Rob, once again, YOU DA MAN!!!!!
Fuse #6 was holding ALL of the power!
I got you a COLD one.
[IMG][/IMG]
Then I drank it. Ya know, Texas-----Indiana, it would have gotten warm!
Thanks for the help.
Old 16 Mar 2017, 07:50 pm
rob302's Avatar
a appreciate the location of the picture vs whats in the can. makes it all worth while.
Power Seat swap on 2008 PT Cruiser Base and no power victort13 General PT Cruiser Discussions 4 07 Jan 2017 08:35 pm
2006 PT Cruiser no power to power seat paradyne64 General PT Cruiser Discussions 5 29 Dec 2016 02:54 am
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
How to: Get power to radio and add circuits for power xwing777 Sound and Security Forum 19 10 Jun 2012 04:49 pm
FIXED: No power to power sockets, front or rear InTheBlack Tech & Performance Forum 2 11 Jan 2011 11:12 pm
