Timing belt replacement question, disconnect A/C lines?
Like Tree2Likes
  • 1 Post By chuzz
  • 1 Post By rckstein
Old 17 Mar 2017, 12:32 pm
rsrocket1's Avatar
Default Timing belt replacement question, disconnect A/C lines?
I am looking at replacing the TB on my 09 Base Cruiser (along with the idlers, water pump, tensioner, center motor mount, drive belts). The car does not have cruise control but it does have A/C. I've read that evacuating and disconnecting the A/C lines greatly speeds up the job.
Should that be done?
I might be able to rent the gauges and pump so the cost would only be for new refrigerant. Otherwise I'd have to pay for the entire evac/recharge job.
Old 17 Mar 2017, 05:00 pm
Default Re: Timing belt replacement question, disconnect A/C lines?
Most members that have done the timing belt themselves have successfully done them without discharging the a/c. I THINK you just have to be careful with how high you raise the engine. WATCH THOSE LINES!!!!!
JDK52 likes this.
Old 17 Mar 2017, 05:05 pm
rckstein's Avatar
While you're in there, you should replace the cam and crank seals
chuzz likes this.
Old 17 Mar 2017, 09:36 pm
WrenchnIswhatIdo's Avatar
Just finished doing T-belt /water pump Did it without removing A/C lines
....W..
Originally Posted by Canadian Moose View Post
Just answer one simple question. Do you own any of the following?: Opel, Alfa Romeo, Fiat, Lada, Yugo, Kia, Daewoo, Volvo, SAAB, Jaguar, Land Rover, Chrysler, Dodge, Plymouth, Jeep, Lancia.
If you answered “yes” then parts car is a really good idea.
Another timing belt replacement question - different guy, different car RVC Tech & Performance Forum 18 21 Jan 2017 11:48 am
Timing Belt Replacement Question BlakeL Tech & Performance Forum 35 16 Jan 2017 05:41 pm
Timing Belt Replacement.... PTMinotaur PT Cruiser Convertible Forum 9 10 Mar 2016 10:06 am
Timing belt replacement dewey68 Turbo Performance 13 16 May 2012 09:53 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
