Possible bad motor/transmission mounts?
  #11 (permalink)
Old 20 Mar 2017, 04:58 pm
Default Re: Possible bad motor/transmission mounts?
The engine mount looks toasted. (1st video)
The engine torque strut (2nd video) is hard to say in the picture. But it is easy to change
http://sacramentoraceway.com/
ADHD=Auto Detailing & Hotrodding Dude
  #12 (permalink)
Old 20 Mar 2017, 05:16 pm
Vengence's Avatar
I figured the Center Mount was just utterly destroyed. That is probably my whole Vibration issue right there. Doesn't look like there is any support.
For the other one, I think it's bad but not as bad. There is still rubber on that one. lol. But, I did notice that 2 parts of it do not touch the center of the mount/strut. One piece of rubber is fully connected to the middle (where the screw goes) and the other 2/3 parts are not.
2008 PT Cruiser LX Inferno Red
  #13 (permalink)
Old 20 Mar 2017, 05:40 pm
rckstein's Avatar
I had the upper and lower torque struts replaced on my PT today, both had torn webs. On the upper it was the front web, that you can't see in your video because it is blocked by the mounting bracket, that was torn.
This tear was allowing enough movement that the bracket was making a clunking or knocking sound when shifting into gear.
After replacement, all is quiet.
'06 Touring Edition NA Automatic
144K Miles / Electric Blue Pearl
USMC '83 - '93
  #14 (permalink)
Old 20 Mar 2017, 07:04 pm
Vengence's Avatar
Well, I am hopeful that replacing these two Mounts/torque struts, will fix the issue. Also be checking the tranny mount which I forgot to look at while I was out there.
How many Motor or Transmission Mounts? chevychad Tech & Performance Forum 12 12 Oct 2016 12:07 pm
motor- transmission mounts tdpope70 General PT Cruiser Discussions 1 30 Sep 2011 11:14 am
motor mounts lt4supr Turbo Performance 9 29 Aug 2011 08:34 pm
Motor mounts sdwilson General PT Cruiser Discussions 4 13 May 2011 10:15 am
Motor mounts sdwilson Tech & Performance Forum 8 03 Aug 2010 12:49 pm
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
