You can have a combination of things that may be problematic.
Check at least these. Check All 3 engine mounts Check Transmission mount Check All Drive Axles Check Compression of cylinder 5 cycle only per cylinder cold Check engine idle with vacuum gauge Check tire wear Check 4 wheel alignment Check tire/wheel balance Check tire air pressure Check LCA's Check for DTCs pending with a diagnostic scanning tool Check for ATX codes. (must be done at a shop) Check transmission fluid |
Check All 3 engine mounts - Lower was replaced last december- will check other 2
Check Transmission mount- will check Check All Drive Axles- Axles were checked- All good. Check Compression of cylinder 5 cycle only per cylinder cold - Everything was resurfaced and compression was checked in all cylinders and all was good then. (Last Month) Unless this process is different? Check engine idle with vacuum gauge- will check Check tire wear- Brand New MasterCraft Glacier 2 tires x4. (Installed in January) Check 4 wheel alignment- Done in January Check tire/wheel balance- Done in January with new tires and checked last week Check tire air pressure- All at recommended levels and no TPM indicator on dash Check LCA's- Not sure what LCA's are Check for DTCs pending with a diagnostic scanning tool- will check Check for ATX codes. (must be done at a shop)- will check Check transmission fluid- this and all fluids were flushed and changed after buying the PT.
My PT's- 2008 PT Cruiser LX Inferno Red 2003 PT Cruiser Base Woody Edition Last edited by Vengence; 19 Mar 2017 at 04:14 pm. |
LCAs are lower control arms. The rear bushing often deteriorates and affects handling and suspension.
I would suggest besides all the great suggestions in the posts above to double check to make sure all spark plugs are working properly. Check for proper gap and defects. Some members have found cracks in the spark plugs and also huge gaps of .095 causing vibrations.
If the spark plugs are okay I would suggest jacking up the front of the PT Cruiser and check the wheel bearings. When they start to go bad they start vibrating at high speeds and gradually start vibrating at lower speeds.
If at First You Don't Succeed - Try, Try Again |
You can visually look at the drive axles but to accurately check them the PT Cruiser should be up on a rack front suspension hung and a helper start the engine and place in gear. Watch listen and evaluate. Even so without being able to load them while testing sometimes it is hard to access a bad axle until it has been removed and the boots removed and joint inspected.
An inner joint can cause a Gremlen of an acceleration vibration only intermittent vibration unlike the tradition clacking of the out joint when turning. Alignment has no estimated time to be true. Although I dont think it is the problem dont over look it. If the alignment was out it could have worn a bad pattern on the tread which can drive a inexperienced Technician crazy sometimes looking for vibrations, shimmies and noises. Look carefully at the out edges of the tires and see if there is any signs of cupping. If the mounts were not installed exactly as per FSM one may have gone bad. Hopefully the lower right engine mount ok. The struts are easy to replace had one or both failed. |
Spark Plugs and Spark Plugs wires were replaced in January as well. That was our original assumption with the Cylinder #2 Misfire. Will check those again again though.
Wheel bearing.....Never even thought of that being a possibility. Thank You. I will look into that as well now.
My PT's- 2008 PT Cruiser LX Inferno Red 2003 PT Cruiser Base Woody Edition |
just a thought but have you given any thout to the measurment after replacing the mounts I think its 119mm or 4.7 inches . Please correct me if i"m wrong. I'm just a beginner. when it comes to pt's.
magoo
06 limited turbo lite Autmatic 104k Magnesium Pearl Not sure about how many owners.I think I'm the third owner. Purchased February 2017. Changed engine oil and Trans filter and fluid. Changed the washer nozzles. Waiting for the weather to change and Then I will change the timing belt and water pump, Motor Mounts All. Brakes. Bell crank. and I am sure I will find other little things to change. I love this car! it's the only car I have ever gone looking for. instead of just looking for best used car at the best price. magoo NC |
Alright guys, I did some looking at the motor mounts. Center and Upper Mounts. Lower was replaced in December 2016.
From my eyes, I believe the Upper is bad and the Center is just destroyed. imo. But, again, I have never seen or replaced a motor mount until now. None of the PT's I owned before ever needed motor/tranny mounts replaced. So, this is based solely on what I can see. Here are some youtube videos of the Center and Upper Motor Mount. Sorry I do not know how to make the video play in the post, so the video links are below. Center Motor Mount- Give it a few seconds to focus, I had to touch an area to get it to focus. https://youtu.be/JYWkFKcROFQ Upper Motor Mount- Took me a few seconds to get it into place, note- you wont be able to see the whole mount, just one side. https://youtu.be/-ctsblMNx0o Please let me know your thoughts/analysis on the videos if you can make anything of them. Thank You.
Thread Tools | |
Display Modes | |
How many Motor or Transmission Mounts? | chevychad | Tech & Performance Forum | 12 | 12 Oct 2016 12:07 pm |
motor- transmission mounts | tdpope70 | General PT Cruiser Discussions | 1 | 30 Sep 2011 11:14 am |
motor mounts | lt4supr | Turbo Performance | 9 | 29 Aug 2011 08:34 pm |
Motor mounts | sdwilson | General PT Cruiser Discussions | 4 | 13 May 2011 10:15 am |
Motor mounts | sdwilson | Tech & Performance Forum | 8 | 03 Aug 2010 12:49 pm |
