25 Mar 2017, 03:44 pm
Re: Push button start
Originally Posted by edscrz
I saw these older posts. They say you need to tun the key on first, that does not make sense, I would like to have it installed with the smart key if possible, like the newer cars have.
there's a kit on ebay to do it and it includes clear instructions. i have it in my closet just have to install it. basically you defeat the interlock in the steering column by removing the lock cylinder and turning the position one forward with a screw driver. then you keep out the lock cylinder, and wire up and glue the start button in the place. you zip-tie the key to the column near the SKIM module to handshake the anti-theft.
then the remote start/passive keyless entry system is installed and wired in. the new modules key fob is the anti-theft device as you cant start the car without it. it acts in the same manner as new cars with keyless systems.
walk up to the car, it unlocks it. go inside the car, push in clutch/brake and push button, the module with crank the engine until the car starts.
