Making noise when turning the wheel
  • 1 Post By RickinPA
Old 25 Mar 2017, 06:42 pm
Default Making noise when turning the wheel
I have a 2004 PT GT manual 5 speed. The car makes a whirring noise when I turn the wheel, whether I am moving or not. I had the power steering pump replaced with a rebuilt one, but that doesn't make any difference. Any clue what else it might be? It's possible the rebuilt pump is bad, but it's an expensive repair and part to be guessing with.
Old 26 Mar 2017, 06:00 am
Default Re: Making noise when turning the wheel
Here's my experience. I'd say check the reservoir for blockage of the filter screen. When the system demands fluid flow, when you're turning the wheel, blockage could choke off flow causing pump cavitation.
JDK52 likes this.
Old 26 Mar 2017, 11:17 am
Vengence's Avatar
You might also want to have your Axles looked at. That is a possibility.
My PT's-
2008 PT Cruiser LX Inferno Red
2003 PT Cruiser Base Woody Edition
Old 26 Mar 2017, 12:22 pm
Thanks Rick. That sounds like that might indeed be the problem.
Old 26 Mar 2017, 12:58 pm
rob302's Avatar
after installing the pump, did you elevate the front wheels, start the car, and turn it lock to lock a few times to bleed out air? if not, try it. it's free and easy
Old 26 Mar 2017, 03:22 pm
Post deleted
2003 GT
My wife is making noise about a new car :( vdbd08pt General PT Cruiser Discussions 27 17 Aug 2014 04:33 pm
Front-Left Wheel making a lot of noise TheDarkAvengerX Wheels, Tires, Suspension 6 11 Mar 2013 01:45 pm
Groan/creaking sound when turning wheel right (front right wheel) 2k2ptc Wheels, Tires, Suspension 8 02 Sep 2012 10:52 am
new here and 05 pt making grinding noise j_bradford911 Tech & Performance Forum 0 13 Nov 2011 02:35 pm
Creaking noise when turning wheel kappa_kruiser Wheels, Tires, Suspension 3 22 Jul 2008 06:14 am
