I have a 2001 Pt crusier base model (Plain, nothing fancy) well recently i changed my oil well, 5000 miles ago at least, had my spark plugs changed, spaced at ,040 or ,40 i believe changed my pcv valve and the hose, (Used a rubber hose that i brought from autozone that i had to SQUEESE in, well i had a small leak which turned out to be the transmission hose but before i knew that i thought it was engine oil so i added a quart or two before my transmission hose gave out and came off leaving my tranny empty, well now i drive and my engine or tranny has a roar and when i approch 50mph i feel my feet and hands vibrating and it sounds like im driving a souped up honda civic, whats going on ? Any thoughts ?
That PCV valve hose might be your problem if it's sucking itself closed.
2001 CHRYSLER PT CRUISER 2.4L L4 PCV (Positive Crankcase Ventilation) Hose | RockAuto
![]() 2006 Touring Edition in Cool Vanilla...aka/Ghost |
You say you added oil, but did you check to see it if was low before you added it? If not then you may have over-serviced the engine with oil and the crank is churning it all up at speed.
I would get it on level ground, warm it up, and check your oil level to rule that possibility out. You also said you had a transmission leak, did you ever check your transmission fluid level?
2003 GT |
You said the transmission lost oil. Did you drive it without oil? Did you refill it?
![]() Downpipe w/Cutout, Magnaflow Catback, Quaife LSD 04' GT Manual Purple PT Mileage: 95k (Died Spring 2018) 05' N/A Automatic Red PT Mileage:121k (Died summer 2017) |
Must have been something simple like servicing the transmission or draining a little engine oil due to over-service....
2003 GT |
Thread Tools | |
Display Modes | |
Sounds Dangerous.. | Mjleisle | General PT Cruiser Discussions | 4 | 15 Nov 2015 01:10 pm |
Because Racecar | midnite72 | Welcome New PT Cruiser Members | 32 | 16 Feb 2014 07:23 pm |
Let's hear what that K E sounds like | Chromenut | Sound and Security Forum | 1 | 18 May 2012 11:23 pm |
Sounds like an Airplane. | 2008NorCal | Tech & Performance Forum | 15 | 05 Oct 2011 11:04 am |
Winding down sounds | Cliff5550 | General PT Cruiser Discussions | 11 | 11 Dec 2008 04:33 pm |
