PT Cruiser 2007 Engine will not turn
  • 1 Post By ptcruisersteve
Old 03 Apr 2017, 10:57 pm
Default PT Cruiser 2007 Engine will not turn
Hi Guys, I am new to this forum. I have a Pt Cruiser it was making a grinding noise come to find out engine was low and the Compressor Pulley was hiting the front bumper and made that grinding noise. I took it to my mobile Mechanic and he replaced the top and bottom motor mount. Car drove well for about a week and the grinding noise was back. I was checking my Car to find out the Compressor pulley is hitting the front bumper again. Further investigation I notice the middle mounts torx screw was loose. I went to Autozone to buy the middle motor mount...... I did not know how difficult it was to replace the mount. Needless to say it took me 2 days to replace the motor mount. I was close to give up. Now after i finished the work I felt good about the wok I did.
Try to start the engine I hear a click and a try to turn for 1 sec. ...... I was beside myself i was at a loss. I was thinking and thinking ....maybe the battery needs to be recharged I recharged the battery installed it and still the same issue hear the starter but the engine does not turn ?????
Need some help please !!!
Old 03 Apr 2017, 11:47 pm
Default Re: PT Cruiser 207 Engine will not turn
I am suggesting that you might have disconnected a wire during your center mount replacement. Was any wires manually disconnected before replacing the center mount?
Did you check the voltage on the wire going to the starter from the ignition switch?
Does the battery voltage drop when you are trying to start the engine?
LionPT likes this.
Old 04 Apr 2017, 12:30 am
rckstein's Avatar
Welcome to the forum
How did you accomplish replacement of the center mount, did you remove the engine?
You should go to the Welcome New PT Cruiser Members section and introduce yourself
Old 04 Apr 2017, 08:23 am
LionPT's Avatar
Check the starter wire.
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... thinkinboutit Tech & Performance Forum 5 22 Jan 2014 08:23 pm
Fan Won't Turn Off; Engine Light 07PEMiami General PT Cruiser Discussions 1 21 Jan 2014 04:45 pm
Engine wants to turn but no spark.. Badcruiser Tech & Performance Forum 9 22 Apr 2011 12:02 am
2008 PT CRUISER WHEN THE AIRBAG IS DEPLOYED DOES THE ENGINE TURN OFF? ilk42 Tech & Performance Forum 1 28 Jun 2010 09:20 pm
Engine Won't Turn Over rfsexton Tech & Performance Forum 17 07 Dec 2009 06:59 pm
