15 Apr 2017, 08:04 am
Re: heater core
Do you have a dealership that you can contact? Using the VIN on your PT, they should be able to give you the MOPAR part numbers for what you need. You should then be able to search online by those part numbers.
Also, I think several members have mentioned that since it is such a huge job to tear out the dash to replace the heater core, that you should also consider replacing the a/c evaporator core at the same time.
It's one of those "might as well" things as you would hate to get your car back together, and then that part go out. Good luck, your in for a big job, take plenty of pics along the way so you can get everything reassembled correctly. I wish you success.
