So, I need to replace my brake lights. The passenger side has a new screw in it, but is stripped. The driver side still has the original screw in it. I am going to replace both bulbs, and both screws. Questions are as follows -
1 - Is it common to need to replace both (or even all three) brake lights at the same time? I have replaced the passenger side 2x now, and the driver side burns out pretty quickly after. I think I had to replace them concurrently on my Neon to keep this from happening. Something about an unequal electrical load... 2 - Any suggestions on screw extraction? I am considering just buying new assemblies and smashing the old ones out... ![]() 3 - Any change anyone happens to know the screw size for these? I am trying to make one trip to the store for everything. Thanks in advance! |
When you say the screw is stripped, do you mean: (1) the torx part you cannot get a torx driver into it? or (2) that you can get a torx driver in it, but it just spins?
If (1) if the torx portion is stripped, there are still 2 notches that you should be able to use a large flat bladed screwdriver to get the screw out. If (2) you may have to gently pull on the light housing while loosening the screw, using the housing as leverage to pull the screw out. You should then be able to take the screw into an auto parts store and find a suitable similar fastener. You can see one of the slots for a flat blade screwdriver at about the 3 o'clock position in this pic, there is another slot on the other side of the screw: ![]() Last edited by rckstein; 15 Apr 2017 at 11:49 am. |
Use a heavy grease to coat the screw and flat nut it screws into before remounting the rear brake lens assembly.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
Thanks, all. The screw that is stripped is a Phillips head, the other side still has the Torx screw in it. Both sides have moisture in them, so I am going to replace both housings. Looks like that will be the best option. Those that have done this before and purchased from Amazon or Rock Auto, did the clips come with the assemblies? I did find the screw on eBay, but it was a couple of dollars, plus 6+ more for shipping. HA! I will take one to the hardware store and get new ones that way.
Forgot to add - 2007 Touring 4 door. I am now looking at LED replacements for bulbs as well.
![]() Quote:
Be sure to look for LED bulbs that are CANbus safe to avoid hyper-flashing and the need to install additional resistors. ![]() |
![]() Quote:
Either use resistors or change out thermal flasher relay |
![]() Quote:
![]() Last edited by Handy_Cruiser; 15 Apr 2017 at 03:32 pm. |
Tags |
2007 pt cruiser, brake light help..., brake lights |
Thread Tools | |
Display Modes | |
Tail light reverse light combo | DODGETHIS | Classifieds: For Sale/Trade | 1 | 09 Jul 2014 07:37 pm |
Brake Light Condensation/Tail Light Replacement? | NewPTCruiserInPA | Tech & Performance Forum | 3 | 23 Jul 2012 09:05 pm |
Mork's Tail Light and Reverse Light Tint Progress | Morkeste | Exterior Accessories Forum | 30 | 23 Jun 2011 12:20 pm |
tail light broken, but brake light works | dirtydmix | General PT Cruiser Discussions | 8 | 09 Mar 2011 09:59 pm |
