I have a 2006 PT C non turbo # 2 cylinder has only 35 lbs compression the others have 175 lbs. I squirted oil in the cylinder and it went up to 100 lbs
but then right back down. I'm think a blown head gasket. It dosen't lose coolent. |
Welcome to the forum.
If at First You Don't Succeed - Try, Try Again |
My guess would not be a Blown Head Gasket. Possible? Yes...But, In my opinion I would check all the Valves in Cylinder #2. Some could be burnt/bent. I am also speaking of experience on this as I had the same issue....although, my compressions wasnt that low......Going to have to take the head off and everything anyways. but my opinion, I think it's a valve issue and not a Head Gasket. Also, if it is just the valves.....better to resurface the engine as well as the Head Gasket.
Side note- If all you are getting error code wise is a P0302 for a cylinder misfire, it may just be what I am assuming.....I think the Head Gasket would throw a totally different code than a cylinder misfire code. (If your getting one at all but, with what your saying, I'm sure you do)
My PT's- 2008 PT Cruiser LX Inferno Red 2003 PT Cruiser Base Woody Edition |
The increase in pressure with oil would lead me to rings. But you may have other issues.
You need to do a leak down test. That will tell you where all the pressure is going. Many vids on how to do this and how to make a makeshift tool. Good luck! |
Hello,
If you did proper cylinder compression checking and comparing to all other cylinders with that amount of low a compression it is easier to remove head and see where the problem is. No matter you would need to remove the head for repairs. Or if you are sure that is the rings remove complete engine and transmission for repairs. Yes I agree that starting engine with a vacuum gauge can see if the valves are the problem. |
Oil adding pressure means rings. If it drains quickly, Its bad. If it is one cylinder you might have a chipped piston on the edge. If you have a china freight bore scope that could do you some good. What color is the smoke coming out of the tail pipe, that will give you some idea as to the head gasket leak type, assuming it was a head gasket. My guess is on the rings, or piston chipping.
![]() Downpipe w/Cutout, Magnaflow Catback, Quaife LSD 04' GT Manual Purple PT Mileage: 95k (Died Spring 2018) 05' N/A Automatic Red PT Mileage:121k (Died summer 2017) |
Thread Tools | |
Display Modes | |
head gasket? Head ? radiator ?????? | rustytoolss | General PT Cruiser Discussions | 15 | 12 Sep 2014 12:57 pm |
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? | 06turbolite | Tech & Performance Forum | 8 | 14 May 2013 09:16 am |
03 pt turbo oil in water new head gasket fresh head | strokedoutss | General Turbo Discussions | 7 | 17 Apr 2013 04:22 pm |
Whats the Head flat spec. for head gasket. | Busted_PT | Tech & Performance Forum | 7 | 26 Apr 2012 08:16 am |
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET | amadeo | Tech & Performance Forum | 5 | 12 Apr 2011 01:03 am |
